- Thank you received: 928
Yanky Iron Fix II
7 years 9 months ago #173161
Replied by Dave_64 on topic Yanky Iron Fix II
7 years 9 months ago #173167
by paulc20
Replied by paulc20 on topic Yanky Iron Fix II
Here is the photo I was looking for. It is taken from "R. G. LeTourneau Heavy Equipment, The Electric Drive Era 1953-1970" by Eric C. O)rlemann. I highly recommend it to anyone interested is this sort of machinery, everything for Sno Buggys to Tree Crushers, Diggers, Forestry gear, Cranes to Missile Launchers.
7 years 9 months ago #173168
Replied by Swishy on topic Yanky Iron Fix II
Gr8 Info Guys
Guessn the overall weight of the beast 2 B the killer
7 years 9 months ago #173169
by paulc20
I guess they could do away with the gearbox, but as you say a 300HP generator and motor aint light. I guess they could use regen braking with resistors (more weight). Modern electronics would make motor control easy and you could set the engine to run at either most economical or most power as required.
I'm not sure if I would want that GM screaming at full noise in the back window though.
7 years 8 months ago #173447
SMore
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13906785_1002269623226353_6432088955350145551_n.jpg?oh=cbe8ced39241eb08b29a14968d54f0ba&oe=58233729
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13729099_991936540926328_5654915035507218435_n.jpg?oh=560efd657927e57b5f5a2e968a7f67c1&oe=585DEC48
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13769432_994663363986979_4772201276799821207_n.jpg?oh=20b10e4160b9822114253d70b9363b32&oe=58230C1F
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13731645_990482487738400_2574616355933818852_n.jpg?oh=7cc61af4c4d7059392774d9932f26836&oe=58177AE0
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13529053_982014591918523_8346702475941776364_n.jpg?oh=7c48fc4065c8ba3298c18f7f9e045b6a&oe=582657A7
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13240526_952376808215635_385897958988937994_n.jpg?oh=040e3821c5eed60165b7905b87f4a7de&oe=5857F6C3
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13237673_948879391898710_5965366205376112262_n.jpg?oh=40c00b4456359a12e266b3e2b18a029a&oe=581D4B5A
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13012745_933787466741236_4233553510262936434_n.jpg?oh=7655696ea2c8899c65e59f0e67eff20b&oe=58197564
https://scontent-syd1-1.xx.fbcdn.net/v/t1.0-9/13139253_946410742145575_7150536214173837657_n.jpg?oh=da809d18413ecf3a45a780099e042d9e&oe=58199E09
The following user(s) said Thank You: 700GMRR
7 years 8 months ago #173451
by defective
...looks like an 8V71 mounted transverse on that GMC.
Replied by defective on topic Yanky Iron Fix II
paulc20 wrote: Here is the photo I was looking for. It is taken from "R. G. LeTourneau Heavy Equipment, The Electric Drive Era 1953-1970" by Eric C. O)rlemann. I highly recommend it to anyone interested is this sort of machinery, everything for Sno Buggys to Tree Crushers, Diggers, Forestry gear, Cranes to Missile Launchers.
7 years 8 months ago - 7 years 8 months ago #173458
Some good 'un's there, Swishy!
I especially like the exhaust arrangements on that Western Terex jigger.
All the screamer lovers would be in orgasmic ecstasy.
Dave_64
Dave_64
Last edit: 7 years 8 months ago by Dave_64.
- Thank you received: 546
7 years 8 months ago #173460
Replied by Blackduck59 on topic Yanky Iron Fix II
For Oilfield trucks I am familiar with the KW 953 (the red one) but not the green 8 wheeler, anyone ID it?
7 years 8 months ago - 7 years 8 months ago #173466
Swishy, your the float man. With that photo of the twin power cat scraper (657??) behind the Pete p/mover, I'm trying to work out the actual decking arrangement of the float. To me, it looks like a normal twin axle dolly with the second gooseneck, but there seems to me to be a heck of a bend in the lower section as well as being very close to the ground. or is it hooked up to the dolly with some sort of drawbar affair? I thought it may be the same arrangement as in the photo's directly above that. where the 4 red Pete's are marshalled in the yard.
I can sort of dig how the decking is made up, trying to get the weight down a bit but still retaining as much strength as possible.
Also looking at the shot of the D11 on the blue float, it looks to be made out of similar material??
Dave_64
Dave_64
7 years 8 months ago #173486
BlakDuk
M80
here B sum noice chassis
Davo
M80
Wot U must relize th@ different parts of the world have different laws
the yanks luv length maily to spread the weight ovr a longr span of bridges etc
the RSend of there LowBoy has a stinger or a widespread set of axles th@ steer
http://media.sandhills.com/img.axd?id=3011887212&wid=TRK&p=&ext=&w=0&h=0&t=&lp=TRK&c=True&wt=False&sz=Max&rt=0&checksum=sssbB6psJ4pfNxCdUF2uyx7lQlp8ucugecyRCnIshKv9dkkJMwW2logXGs3wjEPEOHGliFPThLRTc56u47EuFt%2bvR0Gq%2bung30AcLr10cwZyrFBO2xHZbVGNUg1ycnf5
Them towers they call hat boxes th@ can raise n lower the loaded deck
http://media.sandhills.com/img.axd?id=3011887310&wid=TRK&p=&ext=&w=0&h=0&t=&lp=TRK&c=True&wt=False&sz=Max&rt=0&checksum=sssbB6psJ4pP7J4Jtc8fOroogdH%2fZKOpAGztmZBXmz95dtE8sBlIbDc7H46DC%2bVZsoieooL4IYO5tFjZfccDjVCRhQK4lcDmHjGjiIAjuq3P3O7gnEcGJkXbN1SAMGs6
http://media.sandhills.com/img.axd?id=3011887202&wid=TRK&p=&ext=&w=0&h=0&t=&lp=TRK&c=True&wt=False&sz=Max&rt=0&checksum=sssbB6psJ4p15WEr%2fJu3CQFqOrZRqWHunhcHf0532T8%2fAOh%2bk6LUqnYq2BgEpkskkUSSAzf64nJ%2bSTeXtVsUFs37GIy9yYEnZaDFq9sfJPKgFBBYSTLZiNbmWlXAgCGc
they also make the float decks light weight with a positive camber so wen fully loaded they cum down straight
http://media.sandhills.com/img.axd?id=3004572921&wid=TRK&p=&ext=&w=0&h=0&t=&lp=TRK&c=True&wt=False&sz=Max&rt=0&checksum=t87MT%2b5BqepZvrjymYGvC2GavMagT20UijqKM8KMSpmV8MFilm7AX%2bXNENgsrR5qzEEmZLpLfSaWtfph4qXnA%2fN4815lN91VLyHQQy1rRw0q3jNgk9U1lCDYWTMFV3%2bo
Rear stinger ( U need to pin it wen straight so U can back up)
M80
Davo
M80
Time to create page: 0.525 seconds
