Nash 1 ton truck built early 1920's
- Andrew Gibb
6 years 11 months ago #183506
by Andrew Gibb
Nash 1 ton truck built early 1920's was created by Andrew Gibb
- Andrew Gibb
6 years 11 months ago - 6 years 11 months ago #183507
by Andrew Gibb
Replied by Andrew Gibb on topic Nash 1 ton truck built early 1920's
Last edit: 6 years 11 months ago by Andrew Gibb.
- Thank you received: 4810
6 years 11 months ago #183508
Replied by Mrsmackpaul on topic Nash 1 ton truck built early 1920's
no never have even seen a picture of one
I need to get off the farm more I think :lol:
6 years 11 months ago #183511
Replied by Swishy on topic Nash 1 ton truck built early 1920's
Nash twaz on the agenda sum time ago
www.hcvc.com.au/forum/truck_Chat/2548-nash-trucks
www.hcvc.com.au/forum/truck_Chat/2621-na...-truck-aus-survivors
Also Google tells me
oldcarandtruckpictures.com/AmericanMotors/Nash.html
www.nashcarclub.org/nccaphot/quads/quad_mnu.html
Clik away @ th@ lot should keep U off the streets @ night
- Andrew Gibb
6 years 11 months ago #183601
by Andrew Gibb
Hi,
I have been told of a similar truck at the Gympie Museum.
www.museum.gympiegoldmuseum.com.au/images/FF_NASH_TRUCK.pdf
Cheers.
Cheers.
6 years 11 months ago #183603
Replied by mammoth on topic Nash 1 ton truck built early 1920's
Good find AG. There were 100's of truck builders in the USA in the 20's with most going to the wall or absorbed by other companies in the depression. During that period Australia imported a wide range of those makes and your Nash is one of them. Typically the small (and not so small) truck builders actually made very little themselves, instead assembling components common to many other marques. For example, Continental engine, Brown-lipe transmission, Dayton cast steel wheels in the case of exports, and Timken worm drive rear end. In the 20's most makes stuck to the design parameters of the Liberty Class B which was the USA standard truck for WW1 and which only got into production as war ended. 100 years down the track the advantage is that is that parts and manuals from other trucks may be common to yours.
6 years 11 months ago #183612
by wouldyou
Replied by wouldyou on topic Nash 1 ton truck built early 1920's
Quite likely the Nash truck was an in house product, Charles Nash began his company with the purchase of the Jeffrey Car Company about 1927 which produced the Jeffrey Quad a four wheel drive truck used in World War One. Saw one in the Winton Queensland museum years ago.
David.
David.
6 years 11 months ago #183613
by eerfree
Bob,
I do not know how I got over the hill without ever getting to the top.
Replied by eerfree on topic Nash 1 ton truck built early 1920's
Bob,
The following user(s) said Thank You: Andrew Gibb
6 years 11 months ago #183618
Replied by hayseed on topic Nash 1 ton truck built early 1920's
Must be GM powered...
Time to create page: 0.584 seconds
