- Thank you received: 1836
Trailer Safety Chains, Crossed OR Uncrossed
1 year 6 months ago #240725
Replied by PDU on topic Caption This
1 year 6 months ago #240736
Replied by geoffb on topic Caption This
Just to stir the pot again on chains and shackles
In all of this the load rating I believe is for a constant load not a shock load
Painting colour of shackle read some where is to denote the service / inspection period for these colours
Personally if it comes of the tow ball my preference would be that it completely detach instead of flopping around on a chain
These are just my thoughts and have no influence on what others do
The following user(s) said Thank You: Inter-Action, PaulFH
1 year 6 months ago #240737
Replied by Lang on topic Caption This
Here are some Hitch Fails
And some other beaut towing fails
- Thank you received: 4809
1 year 6 months ago #240753
Thank goodness I'm not a part of caravan forums
I would be moderated out of there pretty smartly
Bring back rams horns
Replied by Mrsmackpaul on topic Caption This
On the caravan Forum I visit from time to time this topic of crossing chains and rated chains and shackles has been bought up a few times. One of the Admin boys posts the rules up and it clearly stated that the chains shall be crossed and no rating on the chain until it is over 750kg trailer and yes the shackles are to be rated. All my shackles have the rating moulded into them. I can only guess that the Chinesium ones do not.
1 year 6 months ago - 1 year 6 months ago #240756
by overnite
Replied by overnite on topic Caption This
As geofbb has stated, I too believe the rating is for lifting (static load), bit useless for a breakaway. Wouldn’t be the first dumb law that some brain dead bureaucrat from the government thought up.
Last edit: 1 year 6 months ago by overnite.
1 year 6 months ago #240761
by wee-allis
Replied by wee-allis on topic Caption This
These are just my thoughts and have no influence on what others do[/quote].
The idea of having the chains catch the drawbar and staying attached to the tow bar is to stop the trailer/caravan becoming an unguided missile and ending up in the path of oncoming traffic.
1 year 6 months ago - 1 year 6 months ago #240762
The thought of a breakaway trailer or van killing an oncoming family does not rest easy with me. I believe the crossed chains are the way to go but don't think the tow bar dropping on to the ground while still being pulled by the chains would be terminal (except maybe for your wires).
I have had two go at highway speed. One in a jeep when the pintle locking lever detached and it opened but the non-crossed chains were too short to allow ground contact. Steering and control was hardly affected.
The second was towing 12 postie bikes on a tandem behind a Canter when the Chinese tow-ball snapped. Crossed chains, no road contact, only indication was the noise.
Whatever system you use make sure you put them on every time!
Last edit: 1 year 6 months ago by Lang.
1 year 6 months ago #240763
by paulc20
Replied by paulc20 on topic Caption This
In my experience, the major advantage of crossed chains is that you can turn tight, and you are are not stretching the outside chains, when crossed, they stay about the same tension as you turn. It is really the length that determines whether the trailer will touch the ground.
1 year 6 months ago #240764
The First Link that Vic Rhodes put up clearly says as Much..!!
www.infrastructure.gov.au/sites/default/...on/files/0-1-3-1.pdf
Replied by hayseed on topic Caption This
1 year 6 months ago #240765
by PaulFH
Replied by PaulFH on topic Caption This
Just my observation, another factor is the total length of some drawbar fittings, some with added ‘levelling’ devices.
Chains shackled to the tow bar frame quite a distance forward of the ball - makes chains too long to keep the trailer a - frame up in the event of coming adrift.
IMO the tow ball should be as close to the rear of the towing vehicle as possible. Keeps the chains short and improves towing stability.
Time to create page: 0.526 seconds
