- Thank you received: 137
Trailer Safety Chains, Crossed OR Uncrossed
1 year 6 months ago - 1 year 6 months ago #240637
Trailer Safety Chains, Crossed OR Uncrossed was created by geoffb
The chain crossed no there a conversation on its own
Last edit: 1 year 6 months ago by hayseed.
The following user(s) said Thank You: Mairjimmy
1 year 6 months ago #240641
by V8Ian
Replied by V8Ian on topic Caption This
My trailer, which is coincidentally the same hammertone green :dry: , has the locking mechanism on the passenger side of the coupling.
- Thank you received: 313
1 year 6 months ago #240643
by Inter-Action
Replied by Inter-Action on topic Caption This
If the handle is at 90 degrees , then the coupling cannot be all the way down on the ball. The recess for the coupling to drop down
on to the ball only works when the handle is in correct position. If that's the case the coupling is not fully engaged with the ball,
but sitting on the top of the ball. ? Side view of ball / coupling may confirm this?
1 year 6 months ago #240646
by wee-allis
Replied by wee-allis on topic Caption This
All this is totally irrelevant. He made the trip without any dramas and Daddy will educate him before the trip back home. All good and a chance for father - son bonding.
1 year 6 months ago #240696
by Mairjimmy
Geoff it seems nobody wants to converse with you about that,,, to cross or not to cross?
Replied by Mairjimmy on topic Caption This
- Thank you received: 46
1 year 6 months ago - 1 year 6 months ago #240700
by Vic Rhodes
Very True..There's no reference to them needing to be Crossed in the Regulations..
www.infrastructure.gov.au/sites/default/...on/files/0-1-3-1.pdf
www.infrastructure.gov.au/infrastructure...n/rvs/bulletins/vsb1
Here's a bit of Interesting reading..
withoutahitch.com.au/crossing-safety-cha...%AC%81tted.%E2%80%9D
Replied by Vic Rhodes on topic Caption This
Last edit: 1 year 6 months ago by Vic Rhodes.
1 year 6 months ago #240702
by V8Ian
I cross mine as I see the logic in doing so, but I don't think it's compulsory. I believe 750kg trailers only require a single chain of the correct rating.
My greatest beef is with those who connect the last link of a long chain. If the trailer became disconnected, the coupling would hit and dig into the road surface.
1 year 6 months ago - 1 year 6 months ago #240703
Replied by Lang on topic Caption This
I have also seen shackles with the pin painted yellow indicating a rated unit without any rating stamped on the shackle - who knows what you are getting in this case. In the picture it looks like one rated and one unrated shackle.
To most people a chain is a chain. Although even a cheap boat anchor style chain from Bunnings is more than likely to be sufficient for a tow ball situation it is nice to have high tensile chain that will probably break the attaching weld or the tow hitch itself before snapping a link.
Last edit: 1 year 6 months ago by Lang.
1 year 6 months ago #240707
Replied by cobbadog on topic Caption This
On the caravan Forum I visit from time to time this topic of crossing chains and rated chains and shackles has been bought up a few times. One of the Admin boys posts the rules up and it clearly stated that the chains shall be crossed and no rating on the chain until it is over 750kg trailer and yes the shackles are to be rated. All my shackles have the rating moulded into them. I can only guess that the Chinesium ones do not.
