- Thank you received: 2
My Dodge D5N Finished....nearly
8 years 4 months ago #165545
by WA Dodge
My Dodge D5N Finished....nearly was created by WA Dodge
Finally finished my Dodge D5N Project. Just getting it licensed now.
Running standard equipment with a 360 engine. I have done the whole thing myself including building the tray from scratch.
Modifications I have made include widening the rear guards by 60mm to square it up with the front. Shortened the tray by 200mm.
I am really happy with it. Just need to get on the road and get some kms on it.
The following user(s) said Thank You: Tacho
8 years 4 months ago #165546
Replied by asw120 on topic My Dodge D5N Finished....nearly
She's come up nice and tidy.
The following user(s) said Thank You: WA Dodge
8 years 4 months ago - 8 years 4 months ago #165547
Replied by hayseed on topic My Dodge D5N Finished....nearly
Good job, there WA dodge.
I'm curious if you have any Pics of the Tub build?
Did you have an old one for a template?
Last edit: 8 years 4 months ago by hayseed.
8 years 4 months ago - 8 years 4 months ago #165550
by ar110
Replied by ar110 on topic My Dodge D5N Finished....nearly
Cool looking ride. You've done a great job and must be happy with your result.
I'm building an AT4 atm in a different style. Colour will also be green but a light mint green.
Don't mean to hijack thread but would you happen to have a D5N manual with wiring schematic that you could copy and send to me cause I'm having troubles with my electrical atm as the previous owner installed a D5N running gear and wiring and its completely different to the AT4. I cant find a schematic anywhere to sort it out.
Cheers Mick. 0410865476
Last edit: 8 years 4 months ago by ar110.
8 years 4 months ago #165551
by WA Dodge
Replied by WA Dodge on topic My Dodge D5N Finished....nearly
Hayseed - yes copied the old tub but modified to suit the things I didn't like about the original. A mate rolled the top edges for me which was my design, sort of F truck/dodge! The bars on the bottom are just straight 30mm tube. I panted it black underneath before finished to save tipping the finished one upside down. I built it on top of my old trailor as made a good work bench height. Here is a couple of photos of the tub build.
8 years 4 months ago #165552
by WA Dodge
ar110 - no I don't have wiring schematic but I used the AT4 manual and also copied a couple of harnesses that I had collected and all where the same. How is yours so different ie what doesn't work?
- Thank you received: 4768
8 years 4 months ago #165553
Replied by Mrsmackpaul on topic My Dodge D5N Finished....nearly
fantastic stuff looks really good to me she's green thats for sure
8 years 4 months ago #165556
by AT4114
Replied by AT4114 on topic My Dodge D5N Finished....nearly
Top looking job there well done the color really suits the truck bet you can't wait to drive it are you running the Dana 60 rear end with 4.11 gears just out of interest ? Cheers Bryant
8 years 4 months ago #165562
by ar110
The state library has 1 copy of the D5N manual but unfortunately is out on loan until next week but I was hoping to have had this sorted by now.
Mick.
Nearly every wire is a different colour. The gauge wire cluster has electric water temp. The dash lights are a larger plastic clip in type and they are all the same colour light blue running 1 wire the same colour to the light switch. the light switch only has 6 wires running to it. Wires to the park lights should be Yellow but mine are Light Green, Wires to indicators should be 1 Light Blue and 1 brown but mine are 1 Yellow and 1 White/ Green. Could keep going on but these are just the noticeable differences of many moreWA Dodge wrote: ar110 - no I don't have wiring schematic but I used the AT4 manual and also copied a couple of harnesses that I had collected and all where the same. How is yours so different ie what doesn't work?
Mick.
