- Thank you received: 3068
2 months 1 week ago #250851
That swaging will complete the job perfectly. I would make the drive to get it done. Chase down either a truck body builder or a panel beating shop that specialise in rust repairs.
2 months 4 days ago #250902
I have seen a ute where aluminium "half round" moulding was attached to straight sheet metal to match the moulding on the original cab.
2 months 4 days ago #250904
2 months 4 days ago #250905
Some ideas
2 months 4 days ago #250907
2 months 4 days ago - 2 months 4 days ago #250909
Great video clips Lang, thanks.
Never heard of joggles before but it would seem joggle/swage to be two names for the same sort of thing. I realised the process but moving on to making the forms is the stumbling block for me.
I think that two strips of 3mm metal taped either side of sheet to be 'joggled' with about 10mm space between them should create the form required when pressed uniformly along the panel. This could be accomplished probably in a wide enough bender by bringing the upper blade down in a hammer manner to form the shape. A press could also be used but unfortunately I have neither to hand.
Maybe a mild bend of about ten degrees would create a clear fold line on the panel, this would create a clear mark to place the edge of one forming strip, flip the metal to place the second strip 10mm from the fold line and put it back into the folder for some gentle "hammer" persuasion.
Please bear with me, watch this space . . .
Last edit: 2 months 4 days ago by PDU.
- Thank you received: 20
2 months 4 days ago #250910
by grumpy gumpy
Replied by grumpy gumpy on topic A was for Austin, but now B is for Bedford
There is a YouTube channel called "Japhands kustoms" that shows different methods of joining sheet metal, mostly steel, he custom builds lots of different things, panels etc. using a lot of hand tools, also tig and mig and machinery. May be some useful info on there
Gumpy
Gumpy
2 months 3 days ago #250913
by grumpy gumpy
Got the tittle wrong, his channel is called "make it custom", his company is Japhands kustom, He's a canadian with a japanese mum.
gumpy
gumpy
2 months 3 days ago #250919
The following user(s) said Thank You: 180wannabe, wee-allis
Time to create page: 2.276 seconds
