- Thank you received: 1836
1 month 1 week ago #251002
Once refitted (partially, but sufficient to show the result) the style line now runs above the step plate and along the turret from the cab . . .
The lower portion is hanging out a bit in these pictures as that will be pulled back flat to the turned up back face of the step plate with screws (pop rivets more likely eventually) . . .
And from the rear . . .
Not forgetting to include an albeit crooked shot of the opposite side, no doubt because I was absolutely stuffed and swimming in my T-shirt yet again!
Thanks again 180wannabe, it has turned out fine.
ALSO I forgot to take any pictures on our mind boggling walkabout, which has left me wondering how many altogether? No need to mention here, message will be great though, ta.
The following user(s) said Thank You: 180wannabe, Mrsmackpaul, PaulFH, asw120, grandad, oliver1950, HalfaDodgeTruckMan
- Thank you received: 4715
1 month 1 week ago #251004
Great stuff, it's amazing how all this stuff sorts it's self out and comes together
Well done on the bending folding to all involved
1 month 1 week ago #251009
Looking good, PDU.
1 month 1 week ago #251020
by wee-allis
Pom, just another example of your attention to detail that you have shown throughout this entire job. I afraid that I fit in with the "It looks good enough, that'll do", brigade, sadly.
Well done as usual.
Steve.
Well done as usual.
Steve.
1 month 1 week ago - 1 month 1 week ago #251031
Having put all the screws back in I had moved on to the front panel of the rear section, immediately behind the cab. This is actually perspex fitted into an angle iron frame unfortunately with a rather wide gap either side (the perspex is cunningly painted except for where the cab window has been duplicated to allow cab to rear section viewing). I was planning to seal these gaps with pieces of T shaped panel joiners used between house wall sections.
However I now intend to use the off-cut piece we used as a test piece before joggling the turret sheets (the piece 180wannabe is folding in my last post). Used as a handy off cut on Wednesday, but now to be split up the middle and cut to match the top curve of the turret once I realised it was exactly the size needed with the bonus of the joggle continuing around the corner between cab and rear section . . .
Just one more example of utilising what would have been simply surplus material!
PS The perspex is actually two pieces of perspex overlapped to also duplicate the joggle. It looks a bit insipid in the first photo above, mildly transluscent, because it is only painted on one side and the light tends to shine through the paint . . . this will not occur once the interior is finished.
Last edit: 1 month 1 week ago by PDU.
1 month 1 week ago #251032
But would only take another pair of rollers to make the stepped offset.
The following user(s) said Thank You: wee-allis
1 month 1 week ago #251041
Not needed cobba, the perspex is fine as is, plus it is painted cream and red already, plus I can guarantee the window won't leak.
Since Friday all I have done is clear the shed around B for, finding tools that have been missing in action for months! Tomorrow and Monday will see the clean-up continue; despite my best intentions the mess accumulates so easily, especially as I tend to hop from one issue to another before completion and don't get back to the previous for weeks (or longer). Agreed, I am a sad case . . .
However, finished or not, by Tuesday (Men's Shed) it will be in a far better state to continue with the truck again, contemplating buying a pneumatic pop rivet gun as there will be a tad over 400 rivets to go into the turret and aluminium strips along the sides.
Perhaps, with my mind wandering towards your mower project, I might even cut my grass by then too???
1 month 1 week ago #251047
You can buy cordless rivit guns that work pretty good
I assume most major brands make them
If you get a brand that matches your existing batteries you can buy just the skin and these are considerably cheaper
1 month 1 week ago #251064
It is now possible to buy knock off battery converter sleds so the first brand you bought no longer has the monopoly on you.
400 sounds like a recipe for blisters, even with one of those double lever type guns.
4 weeks 42 minutes ago - 4 weeks 26 minutes ago #251321
Oh the enjoyment of continual heat, perspiration and never ending requests for my presence elsewhere, it's ongoing . . .
Despite this I have made a start on refitting the sheet metal panels on the turret, picked up an extra can of cream paint (unfortunately not the correct one as I mixed up two cans in my paint cupboard, but at least it should match my Herald now ), polished the aluminium side strips, collected the pneumatic pop rivet gun while in Adelaide for the Tom Jones concert (absolutely tremendous, even though I wouldn't consider myself a TJ fan), spent some time with my brother at the Map Shop (his business), had two very comfortable days in the Inter-continental Hotel (20th floor), and returned home to my foreman (Ollie the dog) and the second pop rivet gun ($20 on line, free delivery that cost them $10;60 for postage!). Phew, who has time to work on a truck?
Easter Weekend so far: rolled on two coats of paint, but will still need one more to standardise the cream colour all over!? I was intending to do one more coat anyway as re-fitting the sunvisor over the side window was bound to result in a scratch or two (it did, two very small ones on the rhs sunvisor). Cab still lingering, and one wheel painted in cream (both sides) to assess whether cream with red edge on rim OR red with cream rim?). Popped the mock-up letters back on to show where they will be painted later.
Pictures to prove it has all happened, as without them it probably hasn't . . .
Last picture is return home from Adelaide, crashed on bed, quickly joined by Ollie and our cat Bertie.
Last edit: 4 weeks 26 minutes ago by PDU.
The following user(s) said Thank You: 180wannabe, cobbadog, Mrsmackpaul, PaulFH, asw120, grandad, wee-allis, oliver1950
Time to create page: 0.630 seconds
