1959 Dodge 3-59D
- Hardtopman
14 years 2 months ago #22326
by Hardtopman
Replied by Hardtopman on topic Re: 1959 Dodge 3-59D
This truck of mine has 7.00 series tyres on a 20" x 5" rim, would these rims be wide enough for a 8.25 or even 9.00 tyre.
14 years 2 months ago #22327
by henryox
Replied by henryox on topic Re: 1959 Dodge 3-59D
Hello, what you have to be careful of is the dish on the wheel , that your bigger tires dont kiss on the duals,
900x20 like 6,5 inch rim and 8.25 a 6 inch, you may get away with the smaller rim and if you go that way it pays to use a smaller size rust band so you can collapse the walls a bit to get the lock ring off, i have F500's here that have 750's on the 700 rim and the duals are kissing without anything on it
Rob
Rob
- Hardtopman
14 years 1 month ago - 14 years 1 month ago #22328
by Hardtopman
What can be done with the brakes on this old girl, its just got the single line hydraulic with no booster. And also will a Commer/Dodge 5 speed overdrive bolt up to the 4 speed (NP435) bellhousing
Last edit: 14 years 1 month ago by Hardtopman.
14 years 1 month ago #22329
Replied by bigcam on topic Re: 1959 Dodge 3-59D
Bruce, just go through them and make sure the cylinders and brake hoses and lines are all right. You can put a vacuum booster on them, I think the PBR one is a VH44, Onetrack will know, which will make the pedal a bit softer.
- Hardtopman
14 years 1 month ago #22330
by Hardtopman
VH44, is that big enough to do the job. also the truck has 5/16 lines where the VH44 i had in my Valiant was only 3/16
14 years 1 month ago #22331
Replied by on topic Re: 1959 Dodge 3-59D
The VH44 isn't big enough, it's only designed for cars. PBR separate their hydroboosters into car and truck types. I don't know what the current models of PBR hydroboosters are, PBR keep changing the models and updating and making others obsolete. All the info I have on PBR braking, is mostly on obsolete models, so I can keep up with changes. If you go along to an ABS Brakes branch, they will set you on the right track for the correct hydrobooster to suit the Dodge.
14 years 1 month ago - 14 years 1 month ago #22332
by doc
Replied by doc on topic Re: 1959 Dodge 3-59D
the after market P B R hydropower unit for a 3 59 was a VH 80. I did have commer 5 speed O/D that was behind a perkins when i took the fly wheel and the clutch plate off the 318 i took it in to a clutch manufacturer i was told that the shaft on the gear box was too big for the clutch plate dia
Last edit: 14 years 1 month ago by doc.
14 years 1 month ago #22333
by kennymopar2
Replied by kennymopar2 on topic Re: 1959 Dodge 3-59D
Quote
not sure how easy it is to find a commer 5 speed overdrive, but there are a few "dodge" overdrive 6 speeds around
14 years 1 month ago #22334
by truckmad
Replied by truckmad on topic Re: 1959 Dodge 3-59D
i can see abit of mopar going on at that house! your in wa? im in armadale
- Hardtopman
14 years 1 month ago - 14 years 1 month ago #22335
by Hardtopman
Time to create page: 0.521 seconds
