- Thank you received: 91
Yanky Iron Fix II
10 years 5 months ago - 10 years 5 months ago #127182
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Re: Yanky Iron Fix II
Me stump the Swish?
Well I'll be something and amazed (a West Oz expression I believe).
th@s godda be wurth a tik it @ thu wotzit frig.
ta,[smiley=beer.gif]
-b
-b
Last edit: 10 years 5 months ago by Bobsboy.
10 years 4 months ago #127183
by Tatra
Replied by Tatra on topic Re: Yanky Iron Fix II
Something from Israel. Looks quite usual for Oz but it's the 1st time I've seen a Jeep dolly set up like this in Israel. Truck is obviously a Mack DM800, most likely assembled by Mack Ashdod. Pic by Mario Segev via Guy Adelist.
Jeep is made out of WWII Rogers trailer.
Descending to the Dead Sea plains, with Autocar cement bulker used as caboose
T
T
10 years 4 months ago #127184
Replied by Swishy on topic Re: Yanky Iron Fix II
BobzBuoy
M80
U may visit u're own fridge any time U like
Jist dun let the boss C u there 2 often
Tatra
Gr8 Pix
keep m Cummin
guess n the only reason to run dolly would B to distance the truck from F B Boat
as most of the weight would B closer to Trailer RSend
M80
Tatra
Gr8 Pix
keep m Cummin
10 years 4 months ago - 10 years 4 months ago #127185
by Tatra
Swishy,
You may be right there... By the way, max weight regs were not strictly enforced back then in Israel and even today anything legal there would give an Aussie inspector palpitations. See below:
Yes these are two M60 tanks (pic source as in my previous post). Prime mover is the below:
Not sure what KW series this is - 853? Pic: I. Mercado.
Cheers,
T
Cheers,
T
Last edit: 10 years 4 months ago by Tatra.
- Thank you received: 4819
10 years 4 months ago #127186
Replied by Mrsmackpaul on topic Re: Yanky Iron Fix II
great pics there Tatra whats all this Ashod business I mean like Leyland Ashod Mack Ashod is it some sort of government thing ? thanks and seeya
10 years 4 months ago - 10 years 4 months ago #127187
by fageol100
Replied by fageol100 on topic Re: Yanky Iron Fix II
Great pictures Tatra, the Kenworth could be an 848 or 849 model, I think the 853 model was a big twin radiator oil field truck.
Last edit: 10 years 4 months ago by fageol100.
10 years 4 months ago #127188
by Tatra
Hamish,
Thanks for the info. By the way, tanks are obviously Centurions, which means even more weight I think...
T
T
10 years 4 months ago #127189
A fu more rivets to count
http://t1.gstatic.com/images?q=tbn:ANd9GcSLLpHjvGW1UJazjkTEY5VIJl3fQYAK8w0LUB7AqLYhx2j7LNU15Q
10 years 4 months ago #127190
by Tatra
Paul,
In the early 60s the Israeli gov't signed an agreement with Leyland to assemble their trucks in Ashdod, on the coast of the Mediterranean. The models assembled all had some local content and ranged from the Chieftain (including an Israel-only bonnetted version) through the Super Beaver/Hippo (with Israeli cabs), Ergomatic types and lastly the Contractor. They also assembled loads of Royal Tiger buses. A part of the deal was to gradually have more local content and even produce bits for Leyland in the UK, but the Poms did not stick tho their part of the bargain and in 1973 the gov't had enough. The factory was taken over by the Israeli Mack importers and assembly switched to obviously Macks, something which went on until 1984. Types assembled were the R600 (some glass front but mostly Flintstones), DM600 (same), MB600, MR600, F700, FM700, Cruise Liner and DM800. Engines were either Mack or Cummins (and maybe one or two Cats).
I hope this makes sense. There is absolutely no connection with the Indian Ashok Leyland...
Paul,
10 years 4 months ago #127191
by Tatra
Neither Plymouth nor Autocar were assembled in Israel
Pic by Fuad Shmally (vie Jakob Aboody).
The below is US made but AFAIK an Israel-only order, the purpose of which was being able to gross 54T with a three-axle trailer legally but in reality a lot more illegally. Cummins 460, 18sp Fuller, not sure about axles but they were stupid rating.
Pic by Z. Gempel whose truck it is.
And the RM is one of two tendering for the IDF's new tank transporter for the 1980s. Berliet axles and V8. Tender won by Austria's
Time to create page: 0.617 seconds
