- Thank you received: 27
Yanky Iron Fix II
10 years 5 months ago - 10 years 5 months ago #127132
Replied by on topic Re: Yanky Iron Fix II
.....i guess i'm missing my old sparring partners....
10 years 5 months ago - 10 years 5 months ago #127133
by Tatra
Is this the one you mean?
I'm also surprized no one mentioned one of these beasts:
Cheers,
T
Replied by Tatra on topic Re: Yanky Iron Fix II
Another weird one, Mack's response to the Brute, the DMM...
I drove something like that in Queensland many years ago the model was DSX811 had 250 c motor quad box heavy arse end on 24 inch rims (grader tryes) triple chassis rails and the best part air over hyd brakes they had 20 cubic metre dump bodies they were owned by Alex Tenkate in bris in the early '80s we worked them on the gateway arterial construction doing the cutting at Mt Petrie near the rifle range also drove an old R22 Euclid that had the 220 cummins removed ond a 400 big cam in it's place but that's another story Regards Peter
Cheers,
T
Last edit: 10 years 5 months ago by Tatra.
10 years 5 months ago #127134
by Phred1
Replied by Phred1 on topic Re: Yanky Iron Fix II
Yeah Tatra just like the first one but a lot more weathered than it Peter
- Thank you received: 4714
10 years 5 months ago #127135
Replied by Mrsmackpaul on topic Re: Yanky Iron Fix II
pure porn that top piccy Tatra ah I will sleep well tonight MMMMMMMMMMMMM BIG MACK
and not the golden arches type
10 years 5 months ago - 10 years 5 months ago #127136
by IHScout
Dennis
Replied by IHScout on topic Re: Yanky Iron Fix II
I flew all the way to Yankee land to get you this fix.
An old Mack still hard at work in Cape Cod, Massachusetts.
This was a mean looking Pete waiting to get onto the ferry to Martha's Vineyard.
And I was amused by this prime mover parked in the middle of Boston with a bicycle at the ready.
Dennis
Last edit: 10 years 5 months ago by IHScout.
10 years 5 months ago #127137
Replied by Swishy on topic Re: Yanky Iron Fix II
Side step n here
to Angle back cabs & recessed exhaust pipes
a rare find on Kenworth Trucks
Ok ok air inlet thru Sleeper
http://t0.gstatic.com/images?q=tbn:ANd9GcQ362gJ8APtAcnZlmukhewg_FA-_puHFP-ICMWpwWaDBkijCy3i
http://t0.gstatic.com/images?q=tbn:ANd9GcQOrzdt6tfthiKvy02N7iDcRVv8XHFMBYd4ZcIeZhsDAkkFrdfVqw
10 years 5 months ago #127138
Jist noticed
iz th@ normal for D front of the rails under COE to taper away n droop down
Wait n on a rivet counters opinion
10 years 5 months ago - 10 years 5 months ago #127139
g'day Swishy and all .. the K100 Series with ''B'' series cab (taper rail chassis) cabovers took over from the 500 Series (straight rail chassis) cabovers.....until KW decided to go back to a straight rail chassis when the improved ''C'' cabover cab emerged in the USA in about 1966
...idstbc and hope that helps.....cheers
10 years 5 months ago #127140
by fageol100
Replied by fageol100 on topic Re: Yanky Iron Fix II
Detective, if the K100B had the tapered rails, what was the K100A series?
10 years 5 months ago #127141
Hi Fageol .. the introduction of K100 Series coincided with the inception of the ''B'' cab....up till then they were simply known as a 500 Series cabover...
...if there is a K100A series cabover, it will be a latter day designation i'm not aware of....cheers
Time to create page: 0.568 seconds
