- Thank you received: 1777
My truck ran over me
Lay down under the draw bar and take a few swings and the slacky, brake frees up and the whole combo starts to roll away. Lucky he was a fast runner and I wasn't laying across the tyre path
- Thank you received: 839
.Only a couple of years ago a B double driver in one of the well known transport companies was hooking up the
trailers . As he plugged in the air lines the whole thing took off and ran over him. The finding was, after backing
under the trailers, the truck was left in neutral and the maxis were not applied..... a fatal mistake........
.........................Billy...........................
I used to be a truck driver,
on a good day i can remember
I have learnt not to get out of the drivers seat with anything else on my mind.
First time I was at CPF for a service, I usually leave here at about 4 to miss some of that early traffic on the Bruce (here is Morayfield)
When I got there this time, there was a bloody prime mover in my spot !!!!
Hummpphh! Will have to pull in behind him. Busting for an early morning dump so took off to the crapper. Sitting there felt some sort of movement, then a thump. Fook me. Looked out the window and the prime mover had backed into me ! Or I had rolled down the hill into him ?
Yup, that was the case, head pokes out of the sleeper and WTF ?
Both get out and start discussing the mangled light bar across the tractor rear, can't remember if it was $5K or $8K he said it cost.
After hanging me out to dry for a few minutes he started pointing out which one the boss had done, which one Dave had done, which one he had done, seems I had only broken one lens of one of the LED's, phew !
Second time, head of our driveway which has a bridge on it, over an easement, off by myself but on a promise, stopped at the top to double check, decided to check the kitchen cupboard doors again, as I was doing that looked out the window and saw the grass beside the driveway going past, backwards ! Up the front in double quick time and yank the lever on, got out to look at the damage, trailer was almost parallel with VP, but 180 degrees from where should have been, coupling broken, box on the front with washing machine torn off, big mess, you get the picture, took some to repair it all.
Now, so paranoid that I sit there for a bit when we stop, apply maxis, know that I have done it but still come back for a check after getting up and walking away.
Only truly happy when all the air has leaked out and I know she is anchored to the ground !
Another recent funny one, had just left Munduberra and stopped at a truck stop for a check as I usually do when it is possible. Found a coolant line to the trailer radiator was leaking and the clip was all the way up. No problem there are some others in the spare tyre well in the trailer, under the Suzuki. Take the car out, nah?
Reckon I can slide down the side of the Suzy and reach the bag of clips. As I was sliding down I had a thought, "I hope I don't get stuck here"
Got the clips out and slid them towards the door and went to get up, you got it, lot easier to slide down than up. Repeated attempts no use.
After lying there considering my options and remembering how cold it was up there the last couple of nights, I decided I had better get myself out of there or I was going to die that night. Once I had that thought in my head it seemed to give me a bit extra and I was able to slide up and out. Next time I will bother taking the car out !!!
Really glad that others make the same FU though !
Whenever I see an airbag equipped truck/trailer parked up, it's down on the bags in no time.
I thought it was pretty poor, having such big leaks that they drop so quickly but now I'm thinking it's deliberate so the maxis come on….just in case the sleeping driver has forgotten ????
- Thank you received: 4815
busman wrote: Yups, easily done.
Bugger me I think we may need to wrap you in bubble wrap LOL
All jokes aside it is good people talk about these things as that is how we learn
It also shows that no matter how good we think we are most times the human is the weak link in the chain
Those that have never stuffed up are either full of crap or have never tried
As a farmer most of my stuff ups are farm related so dont really apply to this forum but saying that I think good luck has a lot to do with the fact that Im still alive rather than just good planning
- Thank you received: 547
One day did it but it was in gear and it jumped forward with front tyre ending up to him.
Unfortunately it killed him.
Have seen a bottle gas delivery truck here in the West with some sort of interlock to the parkbrake, no sure how it was setup but would sound an alarm if you tried to get out without the brake being on.
From memory It was some type of solenoid wired into the interior light switch at the Drivers door..
