USA army trailer ?
11 years 5 months ago #97646
Replied by Lang on topic Re: USA army trailer ?
Swishy,
Unless I am mistaken the White bus and the White Motorhome are one and the same vehicle - all the windows match etc.
11 years 5 months ago #97647
by Marko66
Replied by Marko66 on topic Re: USA army trailer ?
Hi All
Just a quick question does it have eighteen inch rims and tyres with bolt together split rims
Regards Mark
Regards Mark
11 years 5 months ago #97648
Mark,
They have standard US 20" rims with lock ring.
11 years 5 months ago #97649
by Marko66
Hi All
Thanks Lang I am trying to get someting similiar up here and it has the eighteens on it so it may be british i guess or an aussie one
Regards Mark
Regards Mark
11 years 5 months ago - 11 years 5 months ago #97650
Mark,
Sounds British/Australian. You might jump up to Blitz 20" which makes life easy for tyres or down to Blitz 16" if you want to keep the bolt together style.The stud pattern should be the same.
Lots of British (Bedford etc) civilian lock-ring wheels fit that stud pattern too.
Last edit: 11 years 5 months ago by Lang.
11 years 5 months ago #97651
Peninsula bus lines had more than one articulated bus th@ ran the troops down to Portsea n back on RnR
the White in the pic th@ looks like taken @ Rye on the Mornington Peninsula Looks 2 B a White WC 18 or 20
Where by the olmans twaz a White WC22 me thinks
Here B sum other rare beastiez
[ch9787]
Replied by Swishy on topic Re: USA army trailer ?
[ch9787]
11 years 5 months ago - 11 years 5 months ago #97652
Swishy,
Thanks.
Wonder how many little old ladies got dragged under the wheels because they were slow getting on. The White driver only had those tiny 4" mirrors - surely they had a conductor in the trailer who rang the stop start bell?
Just noticed something - is that Portsea bus Left Hand Drive?
Thanks.
11 years 5 months ago #97653
Replied by mammoth on topic Re: USA army trailer ?
Thanks for that Lang. The trailer tares pretty heavy.
- Thank you received: 3
11 years 5 months ago #97654
by Soft-Hearted-Scotsman
Kind Regards
Replied by Soft-Hearted-Scotsman on topic Re: USA army trailer ?
Well done Steve. Be great to have that trailer going to be able to take to rallies. Regards, Stephen
Kind Regards
11 years 5 months ago #97655
More from Lang;
Different manufacturers had different construction methods so while the weight capacity and dimensions remained the same Freuhauf had a rounded deck drop while others had square. Some may have had a very square edge on the roof line while others were rounded etc.
You know the army jeep has these differences with Ford and Willys doing things a different way. Some of the bits don't even look the same but all bolt holes match and they are fully interchangable.
Nearly half the trailers, even bogey trailers, had electric brakes. This makes sense as only the relatively tiny number of prime movers and wreckers had air brakes and most trailers (on dollys) had to be towed by anything. The brake light circuit was used for activation.
They started making these from the WW1 onwards, obviously getting bigger and more sophisticated as time went by.
There were similar trailers made in Australia to be towed by blitz but they generally are smaller and have British pattern wheels. As far as I am aware there were only USA made ones of your larger size. If you start trawling through WW2 photos you will often see this type of trailer in the background (not interesting enough for photographers to feature) particularly in Europe but in all theatres of war. I am sure the yanks brought out many of this style and the Australian forces are more than likely to have ended up with a good number.
Back in the 80's a mate of mine had the twin brother to yours. It was set up for the US Navy as a torpedo compressed air trailer (the US Submarines based out of Brisbane) with a LeRoy multi-stage compressor and banks of pipes for high pressure cylinders. There was the remains of a small workshop with lathes etc at one end. Unfortunately it went to scrap about 1990.
I vaguely remember Wridgeways coming to our house in Perth in 1956 with a Foden towing a "huge" trailer to pick up our furniture to take to Melbourne. I think there would be a good chance it was one of these.
And Onetrack, bless him, applied his forensic mind and come up with a war time photo on
www.territorystories.nt.gov.au/handle/10070/27962
Time to create page: 0.620 seconds
