- Thank you received: 2
1948 Fordson E83W pickup
The Fordson has a grease-point at the centre fixing bolt, that greases between each leaf along a longitudinal depression ground into both sides of the springs. This system ran through all the Fordson, Prefect, Anglia and Populars. If it makes it too slippery, I'll take them out again, clean them down and reassemble them.I thought the rule was NOT to grease the springs, because it removes the friction between the leaves that makes the springs work properly?
They were bloomin' slippery assembling them all greased up!!
Stooging around on google, it looks like springs should remain dry (ungreased) if the suspension does not include shock absorbers. This then (as Beaver points out) relies on the friction of the individual leaves to dampen the ride. If the springs are designed to be greased, then a shock absorber is included in the design to dampen the ride. If the shockies are kaput, then the ride becomes pretty bouncy.I thought the rule was NOT to grease the springs, because it removes the friction between the leaves that makes the springs work properly?
The new Excelsior 6.50-16 tyres arrived during the week so I've started to fit them up the hard way with plenty of detergent and a couple of tyre levers. The rear drums were then fitted with the new bearings and seals and mounted to the axles ... I can't do the front yet as the new bearings don't arrive until Monday.
So far on the rear we've got new spring shackle pins and bushes, new shock absorbers and link arms, new brake linings, wheel bearings and seals, new tyres, plus the general strip down, clean and free up of the various seized bits and pieces, paint, grease up and reassemble. All in all, Clarry is starting to look like he's coming together at last!!
- Thank you received: 36
“The improver of natural knowledge absolutely refuses to acknowledge authority, as such. For him, skepticism is the highest of duties; blind faith the one unpardonable sin.” Thomas Huxley
www.justauto.com.au/justcars/cars-for-sa...text=Back+to+results
After looking at the previous post, thanks for your story and sticking to original.
Cheers, David.
It's a good thing I'm doing up Clarry's brakes though ... I've just realised I've been fitting 'POWER' tubes!!
I've started to strip Clarry's engine down so I can see what I've got. There's a factory rebuild plate on the right side of the block which shows that the engine has already had a rebore to 30 thou oversize, so I guess I haven't got anything up my sleeve there ... just hope I don't need a rebore this time! The crank has only been ground to 10 thou undersize, so I've got a fair bit of life left in that. Cross fingers!!
the engine has already had a rebore to 30 thou oversize, so I guess I haven't got anything up my sleeve there...
Probably easy enuf to re sleeve if yer need to.
Looks like the ute at Dalby has sold. Wonder if a lurker here bought it
Bloody fantastic workmanship.
Trevor
