- Thank you received: 2
1948 Fordson E83W pickup
Hi Ray and Geoff - I too was also told around 3-5 thou per inch of bore diameter as a ball-park gap, but these are the figures given by the ring supplier. Perhaps when he said "ring gap" he meant "ring gap per inch of bore diameter". Clarry's bore diameter is 2.5", so I might err on the side of caution and gap to around 10 thou. If it ran before with the big gap it had, it'll run better with 0.010!I was always told .003 per inch of bore in normal engines as well
I will be taking Clarry to the Humpty Doo 'show and shine' next Sunday, so I'll dummy-mount the engine and gearbox in the chassis, even though it'll be missing the crankshaft, pistons, flywheel and things.
I also stripped down and cleaned the oil pump, and reassembled it ready for fitting. It was quite dirty around the gauze screen, which in the small Fords is the primary filter, as there is no other. There's an after-market filter arrangement available, which I have already purchased to fit to Clarry when I re-fit the engine. I hate the thought of unfiltered oil passing around the engine!!
This should answer that one ...Just a quick question Bugly what paint did you use on Clarys chassis and how did you apply it looks fantastic
... and the aerosol cans are invaluable for quick touch-ups!!Hi Barnyard. With all of Clarry's undercarriage and other bits, I scraped all the crud off and gave it a good wire brush down. I then gave it a treatment of White Knight Rust Converter www.whiteknightpaints.com.au/specialty-p.../prep/rust-converter before a couple of coats of White Knight Epoxy Enamel applied by brush www.whiteknightpaints.com.au/specialty-p...topcoat/epoxy-enamel
The paint is quite hard, and I'm happy with it. I keep a couple of cans of White Knight Epoxy Enamel in aerosol cans for touch-ups and for painting the little bits. Except for the chassis, the rest of the bits and pieces were primed with White Knight All Purpose Primer www.whiteknightpaints.com.au/specialty-p...r/all-purpose-primer
Forgive me if I sound like an ad for 'W-K' :
Don't worry P-B ... I'll slow up drastically once I get to the body repair!!credit to you Bugly and a super fast build too. ps ur putting me to shame. at the rate im doing my cab build
