- Thank you received: 1104
Cummins 160 parked for 10 years. Will it run?
8 months 2 weeks ago #247383
Replied by asw120 on topic Cummins 160 parked for 10 years. Will it run?
Knew a bloke who turned his vacuum into a jet engine doing this, albeit with petrol. (no, it wasn't me )
8 months 2 weeks ago #247385
by Gryphon
Replied by Gryphon on topic Cummins 160 parked for 10 years. Will it run?
Hi,
I use a sand blasting gun and an air compressor and drop the pick up line in the fuel tank and suck the crud out, however if it is behind baffles you wont get all of it out.
Terry
Terry
- Thank you received: 4758
8 months 2 weeks ago #247389
I think it would be not a issue with diesel
If it was mine I would just cut a hole in it with the fuel still in there
Just make sure the air hose has been pumping away for a little while before you start
I have done a few tanks and even bunged one on youtube once
And I haven't gone bang yet
When it comes to welding it back up diesel is more dangerous than petrol but if the correct proceedure is followed it is fine
Replied by Mrsmackpaul on topic Cummins 160 parked for 10 years. Will it run?
dont know if a wet and dry would be a good idea........ on mine ,you can see sparks from the brushes in the electric motor ............maybe the more modern ones are OK.
- Thank you received: 313
8 months 2 weeks ago #247391
by Inter-Action
Replied by Inter-Action on topic Cummins 160 parked for 10 years. Will it run?
I have a C1500 with the original tank still in situ . Would that have a suitable sender unit for what u want?
8 months 2 weeks ago #247394
Replied by JOHN.K. on topic Cummins 160 parked for 10 years. Will it run?
If the tank is the same depth ,it should be OK
- Thank you received: 600
8 months 2 weeks ago #247398
Replied by 180wannabe on topic Cummins 160 parked for 10 years. Will it run?
The D-Line service manual says the fuel sender unit should be a 10-180 ohm unit, which a quick google search shows to be very common/readily available.
Brett.
Brett.
The following user(s) said Thank You: IHScout, Mrsmackpaul
8 months 2 weeks ago #247405
Replied by cobbadog on topic Cummins 160 parked for 10 years. Will it run?
I have an air compressor vacuum. A length of hose with an air gun poked into the wall of the tube with enough length to drop down into the tank and other end long enough to allow the muck to bloww away from me.Connect to the air line and run over 50psi or higher and watch it work.
8 months 2 weeks ago #247406
by IHScout
Dennis
Replied by IHScout on topic Cummins 160 parked for 10 years. Will it run?
Thanks everyone for the helpful ideas and information. It doesn’t look like I’m going to get a chance to try starting it until after our next lot of holidays. So stay tuned for the next instalment sometime in October!
Dennis
8 months 2 weeks ago #247415
by Inter-Action
Me to cobbadog. When i drain my stationary engine cooling systems, i use a piece plastic hose. Punch a hole in the side at the outlet
end , about 100 mm down from the end. Jam the air gun nozzle into the hole , air on and the venturi system does the rest.
Works really well and you can direct the suction end into all the tight spots. Of cause you have to unblock the suction of rust and
rubbish regularly.
Dave.
rubbish regularly.
Dave.
The following user(s) said Thank You: IHScout, 180wannabe, cobbadog, PaulFH, Brocky45, theabundantlife
8 months 1 week ago #247442
yeah, that was what I was trying to describe
The following user(s) said Thank You: Inter-Action
Time to create page: 0.573 seconds
