Rebuild of AT4114
9 years 1 week ago - 9 years 1 week ago #125753
by AT4114
Ok some more progress pictures almost ready to chuck the cab back on the chassis
http://i.imgur.com/FS0udDL.jpg?1
http://i.imgur.com/80d05Jd.jpg?1
http://i.imgur.com/t3BvQAK.jpg?1
http://i.imgur.com/orgNAvF.jpg?1
http://i.imgur.com/ecTkDX0.jpg?1
Last edit: 9 years 1 week ago by AT4114.
9 years 1 week ago #125754
Replied by asw120 on topic Re: Rebuild of AT4114
It's going to be a good thing!
Now, while you have it on its back, I'm serious about checking under the dash around the vents. Have a real good poke around with a screwdriver. Make sure it's all rock solid. Finding the pinholes now will will pay dividends later. Annoying incurable leaks are the other option.
With luck, there's none to be found. Also, IIRC, there are some drain holes at the outer ends. This is the bit that fills up with mud and rusts out between the bonnet and doors. Now is the time to deal with it permanently.
Keep up the good work, Jarrod.
9 years 1 week ago #125755
by Mac 57
Replied by Mac 57 on topic Re: Rebuild of AT4114
9 years 1 week ago #125756
by AT4114
Jarrod and Mac thanks for the advice and the pictures I've had a real good poke around with a screw driver and had a bit of a look inside the plenum chamber and it's still very solid and rust free the cab came from out west nsw and had never lived by the coast . I will be flooding it out with fish oil when it's painted so hopefully it should last a few more years . Mac you have done a fantastic job with your resto well done cheers Bryant
9 years 1 week ago #125757
That's good, Bryant. Just make sure the drains are clear. Can't remember what they look like at the moment, might be just a gap, or what.
Cheers, Jarrod.
Cheers, Jarrod.
9 years 6 days ago #125758
by AT4114
Will do jarrod thanks mate
8 years 11 months ago #125759
by AT4114
Quick updat I've cleaned up under the dash and firewall I will also re seal the plenum chamber joint with sika flex when the red oxide paint dries then I'm ready to start the bodywork on the cab cheers Bryant
http://i.imgur.com/mMsisag.png?1
http://i.imgur.com/dNq99Q3.png?1
http://i.imgur.com/f6k7NSN.png?1
http://i.imgur.com/XhMW4Wz.png?1
http://i.imgur.com/ztYZ1MV.png?1
8 years 11 months ago #125760
You've done well. I'd flood that plenum with whatever sealant/rustproofer you can so it stays like that.
Best basis for a good resto, a cab like that one.
Cheers.
Cheers.
8 years 11 months ago #125761
by AT4114
Thanks jarrod I plan on blocking up the drain holes and flooding the plenum chamber with penatrol after the cabs painted I will also be giving the internal roof gutter around the edge of the rooflinning a good dose as well . Hope you get your inter sorted soon cheers Bryant
8 years 11 months ago #125762
by AT4114
While I'm waiting for some workshop space at a mates shed so I can strip and paint the cab I've started to strip the doors and get them ready for etch prime and high fill the passenger door is good to go and the drivers door was in need of some small rust repairs to the underside it took me ages to remove the petrified quarter vent rubbers cheers Bryant
http://i.imgur.com/WW9RCNW.jpg?1
http://i.imgur.com/V4BXiYQ.jpg?1
http://i.imgur.com/QkgsGif.jpg?1
http://i.imgur.com/cu5gpdw.jpg?1
http://i.imgur.com/D5FFqXZ.jpg?1
http://i.imgur.com/NlGJ03A.jpg?1
http://i.imgur.com/NqQr2Dk.jpg?1
