Rebuild of AT4114
9 years 4 months ago #125723
by Backyard Fixer
Replied by Backyard Fixer on topic Re: Rebuild of AT4114
Is your carbie setup for straight gas?
9 years 4 months ago #125724
by AT4114
Gee Bugly I'd be over the moon if it drove like a new one . Hi backyard the induction setup is for straight gas it's an impco 425 carb on a carter thermoquod base sitting on top of a factory cast iron 4bbl manafold should be a good match for the 318 cheers Bryant
9 years 4 months ago - 9 years 4 months ago #125725
by AT4114
Ok started on the rust repairs to the floor pans today this is my first attempt at any thing like this so some of the images may be disturbing to some of you experianced restorers I am butt welding the joins so it hopefully won't look like a patchwork quilt . Tomorrow I hope to finish fully welding the joins and get the upper firewall section cut out and siting in place so it can be welded cheers Bryant
http://i.imgur.com/4DgA3nJ.png?1
http://i.imgur.com/h2mkce9.png?1
http://i.imgur.com/37osbxh.png?1
http://i.imgur.com/KQSSU2U.png?1
Last edit: 9 years 4 months ago by AT4114.
9 years 4 months ago #125726
by AT4 353
she'll be Jake.
Replied by AT4 353 on topic Re: Rebuild of AT4114
Good to see you are motivated, wont be long and you will be putting the cab back on the chassis.
she'll be Jake.
9 years 4 months ago #125727
by AT4114
Thanks mate Hopefully we will both have our AT4,s up and running sooner than later
9 years 4 months ago #125728
Replied by asw120 on topic Re: Rebuild of AT4114
Bryant, looking good. You're a brave man butt-welding; I lap-weld everything where possible. (preferably by flanging one part so it ends more-or-less flush.)
However you do it, preparation is everything.
9 years 4 months ago #125729
by dieseldog
Replied by dieseldog on topic Re: Rebuild of AT4114
Looking good there, Bryant. What type of steel are you using- straight mild or zincanneal? I can't really see from the pictures. Zincanneal is probably the best in this application but if you use mild steel just make sure you paint it with a zinc rich primer for good protection against corrosion.
With the welding, just make sure that your getting good penetration so you effectively turn the patch into one piece with the rest of the floor. If you need to, get a block of copper or brass to put behind the weld and really get the heat into the weld.
9 years 4 months ago #125730
by AT4 353
she'll be Jake.
you can flatten a piece of copper pipe at one end and use it
underneath where you are welding.
she'll be Jake.
9 years 4 months ago #125731
by AT4114
Thanks dieseldog and 353 I have been using a large piece of copper pipe with about 6 inches of one end flattened out it seems to be a good heat sink . Diesel I'm using 16 guage cold rolled sheet steel thanks for the tip on the zinc rich primer the more I weld the better the finish I'm hearing you about the penetration as I've been checking the underside of the welds as I go along cheers Bryant
9 years 4 months ago #125732
by AT4114
Ok got the LH side done apart from some seam sealing and tidy up . Started on the RH side when this is done the cab will be rust free then I will tip it on its back so I can clean up the underside and strip and paint the cab so I can bolt it back on its chassis
http://i.imgur.com/gIfmkju.png?1
http://i.imgur.com/LCb1U05.png?1
http://i.imgur.com/DQ0kM3O.jpg?1
http://i.imgur.com/kZvJsFg.jpg?1
http://i.imgur.com/meCcSzw.jpg?1
Time to create page: 0.542 seconds
