- Thank you received: 1115
International AR-110 Ute
9 years 10 months ago #138589
Geez that's nice.
9 years 10 months ago #138590
by grahamjb
Thanks asw120
9 years 10 months ago #138591
Replied by on topic Re: International AR-110 Ute
Graham
Fantastic work on the trimming this beast is gunna look awesome when it rolls down the road
Trevor
Trevor
9 years 10 months ago #138592
by grahamjb
My new springs arrived
Pretty blue colour
They are 10mm shorter than the ones fitted but the diameter of the steel is 19mm compared to 16mm and the new ones weigh 6kg each whereas the old ones weigh 3.9kg each
I have fitted the drivers side spring after a lot of grunting
Should get the other one fitted tomorrow and then I will attack the inner guards to fix where the tyres rub grr
Pretty blue colour
9 years 9 months ago - 9 years 9 months ago #138593
by grahamjb
Both front springs have been replaced which has given and extra four inches of ride height. I have modified the front inner guards by adding another 120mm box section to increase the size of the recess which should stop the tyres rubbing on full lock.
Made up these box sections to fit to each inner guard
Managed to put some colour on the modified inner guards after work today.
This is the passengers side and I have had to chamfer the extension box section to clear the Alternator adjusting bracket and also to provide clearance for the bottom radiator hose. I also drilled some large holes to help the heat from the extractors dissipate quicker
Drivers side extended box section inner guard
Last edit: 9 years 9 months ago by grahamjb.
9 years 9 months ago #138594
by grahamjb
Put the inner guards back on, fitted the bonnet hold down/release catches, the bonnet struts/stays and made up some gasket strip for where the outer guard bolts on.
I also fitted the windscreen washer bottle on the passengers inner guard near the overflow tank which took longer than planned because I wanted to hide the wiring.
This photo shows the passenger side inner guard ready for the outside guard
Made a start on fitting the passengers outside guard
9 years 9 months ago #138595
by grahamjb
9 years 9 months ago #138596
The attention to detail continues. I dream of building something to this standard (without just chucking it in 3/4 of the way through and throwing the last bits together). I expect you'll get a lot of joy out of this one when it's on the road.
9 years 9 months ago #138597
by Tacho
Replied by Tacho on topic Re: International AR-110 Ute
This resto and the detail is so incredibly neat. I takes me hat off to you Graham.
9 years 9 months ago #138598
by grahamjb
Time to create page: 0.614 seconds
