- Thank you received: 2
International AR-110 Ute
9 years 9 months ago #138599
by Bugly
Replied by Bugly on topic Re: International AR-110 Ute
I doubt whether it looked this good coming out of the factory!! Great rebuild Graham!! [smiley=thumbsup.gif] And keep on posting those pictures!!
9 years 9 months ago - 9 years 9 months ago #138600
by grahamjb
Finished making the last A/C hose/pipe after work today. I had to fit a length of aluminium pipe to the high pressure compressor hose so that I could connect it to the condenser. (I couldn't run rubber hose all the way to the condenser because the turn radius was too tight.
I cut out the centre section of this aluminium pipe and made a right angle pipe that would connect to the compressor hose
This is the finished pipe but it is hard to show in the photo due to restricted room
Another view showing the compressor hose fitting at the bottom and you can also see the TIG join where I cut the pipe
Vacuuming out the system - fingers crossed the system will hold vacuum and then I can gas it up.
Last edit: 9 years 9 months ago by grahamjb.
9 years 9 months ago #138601
by 600Dodge
Replied by 600Dodge on topic Re: International AR-110 Ute
Which gas are you using?
9 years 9 months ago #138603
by Coupeute
Replied by Coupeute on topic Re: International AR-110 Ute
All ready for a Perth summer cruise. Looking good.
9 years 9 months ago #138604
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Re: International AR-110 Ute
Hi,
Now he's a fridgie.
Does this mans talent ever end?
Isn't HCVC amazing?
-b
Now he's a fridgie.
Isn't HCVC amazing?
-b
9 years 9 months ago #138605
Replied by geoffb on topic Re: International AR-110 Ute
Pipe the Ac into the glove box as a cooler
9 years 9 months ago #138606
by grahamjb
Not a bad idea Geoff, then I could get rid the of the esky on the seat beside me
9 years 9 months ago #138607
by grahamjb
I need an airbox and the VX Commodore one I have is way too big and totally the wrong shape to fit inside the engine bay.
Removed the unwanted bits of the Commodore airbox
Put some fibreglass over what was left and I now have something that I can start to work with
More to follow when I decide where to mount it
9 years 9 months ago #138608
by grahamjb
Worked out how to mount the air filter box by drilling and tapping some holes in the inlet manifold
Made some brackets from scrap aluminium
This is where the air filter box will be located and it won't look this ugly after I have finished and painted it
I have these bits to play with which is a cold air intake from my sons VN Commodore, the air duct from the VX airbox and some flexible duct
This photo shows the general concept but I am not convinced about using the cold air intake assy - I am more inclined to cut an oval slot in the bottom of the air filter box and do away with the cold air intake and associated ducting
Time to create page: 0.624 seconds
