- Thank you received: 928
Transport and plant/equipment used in/on Snowy Scheme
7 years 9 months ago #172034
Replied by Dave_64 on topic Transport and plant/equipment used in/on Snowy Scheme
Just going on those gear shift diagrams on the dash board of the Antar, would they have been running David Brown gearboxes, similar to some of the early Fodens??
Dave_64
Dave_64
7 years 9 months ago #172036
What about diffs? Kirkstall Omega??
Dave_64
Dave_64
7 years 9 months ago - 7 years 9 months ago #172057
by andy950
Replied by andy950 on topic Transport and plant/equipment used in/on Snowy Scheme
I think the only surviving part of these 3 Antars is a grill out of one, the one the Ryes have at Berridale isnt from the scheme.
Also if anyone is interested there are some photos on facebook on a page called "old NSW album" theres pics of a peterbilt low loader with a dump truck going through the hole in the wall, very tight squeeze.
Last edit: 7 years 9 months ago by andy950.
7 years 9 months ago #172062
by bruehawk
Replied by bruehawk on topic Transport and plant/equipment used in/on Snowy Scheme
This photo from the National Library shows the Antar's descending down the access road to T1 Power Station from Cabramurra. The load is made of concrete blocks and was a test run to ensure that it would all go to plan when the generating equipment was transported into the power station. The trucks have just changed direction at one of the switchbacks. Phil Rye has two Antar trucks in his collection, both obtained from the UK.
7 years 9 months ago #172076
Replied by Dave_64 on topic Lifting stuff from facebook
What's the ruling on stuff posted on Facebook anyway? Once up, is it fair game to everyone? I wanted to have a look at that Pete with the float going through the hole-in-the-wall, suspecting it's one of Canningtons.
Anyway someone who is facebook savvy (I'm not even on it, enough trouble getting on an ordinary forum) may be able to get a copy and post it here?
Thanks, Dave_64
Thanks, Dave_64
7 years 9 months ago #172079
Replied by Swishy on topic Transport and plant/equipment used in/on Snowy Scheme
Davo
Gudday m8
Tha@ BnW pic BruHawk put up
wunder
if they unhook in the swing basin n rehook Arse about n tow the trailer backwards
az there dun seem nuff turning area to get the big wompus around
RE: PetePic
U mean thiz n Y/N
https://scontent-lax3-1.xx.fbcdn.net/v/t1.0-9/984304_1587397328211689_1215799251833666128_n.jpg?oh=4b3ba645e33711be9ad4748f9d167666&oe=582B75A1
leme kno if nutn developes
Gudday m8
wunder
RE: PetePic
U mean thiz n Y/N
7 years 9 months ago #172081
Thanks for that one, Ted. The one I couldn't get was one off facebook, apparently one of a float (Canningtons?) coming through the Picton viaduct. I'm not on it (facebook) so can't see a piccy. Going by the posting, had a rear dumper on, probably one of those Haulpak 75's??
Dave
Dave
7 years 9 months ago #172085
Replied by hayseed on topic Transport and plant/equipment used in/on Snowy Scheme
Swishy, Pretty sure there's enough room to the Left (out of Frame) to get it all around. I have seen other pics of that road..
Dave, That pic you're looking for might be in here somewhere ( I haven't looked right through for a while) .
www.hcvc.com.au/forum/OldTruck/6755-cann...t-pct-road-lines-p-l ..
- Thank you received: 1174
7 years 9 months ago - 7 years 9 months ago #172093
by Southbound
Replied by Southbound on topic Transport and plant/equipment used in/on Snowy Scheme
Swishy is on the money, the switchback going down to T1 is too tight to swing that load around in. I did 3 loads down there last year in a normal semi and it takes a few goes to complete the turn
Cheers Ross
Cheers Ross
Last edit: 7 years 9 months ago by Southbound.
7 years 9 months ago #172096
by rex
Replied by rex on topic Transport and plant/equipment used in/on Snowy Scheme
There is no way they could go around the switch back with that gear.
We have during the last three Years delivered seven new Transformers down and seven old ones back up.
You go forward down to the switchback and reverse to T1. the Transformer is in Beams due to a height of
4.90 metres. the old Transformers were of an expensive build and could be rolled on their side, due mainly to the equipment when they were installed.
We took the old Transformers out going forward from T1 on an 8 axle platform, did a several point turn at the switchback and worked our way uo to the top travelling in a forward direction.
Given what we had to do the job and what the men had with the Antars to work with, I tip my hat to them, wish there were a few like them looking to help me get the job done now.
Rex
Rex
