- Thank you received: 257
Ahhh......Dodge or inter door latches
12 years 8 months ago #62246
by 600Dodge
Ahhh......Dodge or inter door latches was created by 600Dodge
Does anyone know of a source for Dodge or inter door latches or something that can be modified/adapted to keep Dodge doors doing what they should. Two of my Dodges are afflicted with door latch disease, one won't open and one won't stay shut, Ive stripped both doors and the catches are U/S and can't be repaired and I would like something to repair them with apart from the dodgy padbolt set up.
12 years 8 months ago #62247
by Hardtopman
Replied by Hardtopman on topic Re: Ahhh......Dodge or inter door latches
R series Mack use the same door handles on the outside so maybe the latch is also the same.
12 years 8 months ago #62248
Replied by bigcam on topic Re: Ahhh......Dodge or inter door latches
Mine's got a pad bolt on the inside, it's pretty effective.
12 years 8 months ago #62249
Replied by Sarge on topic Re: Ahhh......Dodge or inter door latches
600, are you looking for the guts at the back of the handle or the razor back latch on the pillar or the toungue bit that hooks on the razor back??
EMNTK
/me
EMNTK
/me
12 years 8 months ago - 12 years 8 months ago #62250
by ct7scott
At4 560 313&&At4 129 225&&HR
Replied by ct7scott on topic Re: Ahhh......Dodge or inter door latches
plus 2 for the padbolt, I gather your after D5N and not AT4
then
then
Last edit: 12 years 8 months ago by ct7scott.
12 years 8 months ago #62251
by 600Dodge
Replied by 600Dodge on topic Re: Ahhh......Dodge or inter door latches
D5n and the bit I'm after is the latch part inside the door that holds on to the loop on the B pillar, I was thinking maybe 2070 or abouts inter stuff might be able to be obtained new if they are the same.
- Thank you received: 5
12 years 8 months ago #62252
by Aussiehooker
Replied by Aussiehooker on topic Re: Ahhh......Dodge or inter door latches
the loop bit sounds different they are lift up handles i take it and not press button conventional type
