Cab-----------------------Over
10 years 7 months ago #128311
Cab-----------------------Over was created by Swishy
10 years 7 months ago #128312
Replied by bigcam on topic Re: Cab-----------------------Over
Where's the leaker gone out of the Atkinson Swishy?
10 years 7 months ago #128313
Replied by Swishy on topic Re: Cab-----------------------Over
Into KW 1/2 Truck
Power 2 D ppl
Power 2 D ppl
10 years 7 months ago #128314
Was it a 6V or an 8V?
Has the 1/2 truck had a power upgrade of 2 more cylinders?
That green is a better colour than the silver too.
10 years 7 months ago #128315
by angle-iron
Replied by angle-iron on topic Re: Cab-----------------------Over
Still havin trouble with that cab tilt cyl swish?
10 years 7 months ago #128316
Big C
M80
the 1/2 truck twaz V6-71 238 screeem n ponies
now added 2 more Cylinders V8-71 318 hp
tight fit to shoe horn it in..specially wiff a wiked wench right in the way
guna run twin exhausts one on each side of the Wiked
Angel Eye n
nu cup sealz in tilt rams = dun ....... like a newy now
www.hcvc.com.au/forum/YaBB.pl?num=1375847366
M80
Angel Eye n
10 years 7 months ago - 10 years 7 months ago #128317
Replied by on topic Re: Cab-----------------------Over
....jeeez Swishy .. now you'll be able to put the roller at the back to good use as a full throttle wheelie bar as well!!
10 years 7 months ago #128318
10 years 7 months ago #128319
Swish, if that winch works off the PTO, wouldn't you have to move it back with the gearbox?
10 years 7 months ago #128320
BigC
M80 mechanical chain drive
probly set it all back up when beast B happy n runn n again
a direct drive PTO chain to Wench
pto - Uni - 100 mm shaft - sproket - plummer blok
guna have to duble shaft it thru nuther set of sprokets n chain to move it back forward 50mm az the V8 tiz 155mm longer than V6
Time to create page: 0.490 seconds
