- Thank you received: 18
International AR-110 Ute
9 years 2 weeks ago #138679
by grahamjb
The reason for toying with re-sleeving the M/C bore is because a larger master cylinder bore produces more volume whereas a smaller master cylinder bore produces more pressure. The Jag M/C has a 7/8" bore and the XB M/C is 1". Re-sleeving this means that I won't have to re-plumb the brake lines or make a new booster mounting bracket.
Fitting a Jag booster M/C would have been the best choice but I was advised that the the setup I am using would work fine and it was available at the right price. Have to check the booster to see if it is faulty as fitting a larger diameter booster will be a problem but it may be the best solution along with a Jag M/C.
This is when I really wish I had a hoist!
9 years 2 weeks ago - 9 years 2 weeks ago #138680
by grahamjb
I picked up a 7" dual diaphragm booster from Armadale Auto spares this morning and the guys at Roadbend in Welshpool were kind enough to provide me with a second hand remote fill M/C which I have now modified to fit the new booster.
New 7" dual Diaphragm booster and second hand M/C
New remote fill reservoir - the most expensive piece of plastic on the planet
A comparison of new and old Booster & M/C assys
The Gemini booster mounting holes are 90mm spacing and the new booster has 85mm spacing which the step drill will fix tomorrow.
More tomorrow
More tomorrow
Last edit: 9 years 2 weeks ago by grahamjb.
9 years 2 weeks ago #138681
by Zuffen
Replied by Zuffen on topic Re: International AR-110 Ute
That M/c would allow you to weld up the access hole in the floor, one less potential leak.
I'd forgotten about Roadbend. We used to use them when we had an office in Perth, around 15 ears ago.
9 years 2 weeks ago #138682
by grahamjb
Zuffen
I don't have a M/C access hole in the floor to worry about. I had to use a mirror when filling the Falcon M/C which is inconvenient to say the least.
The remote fill Jag M/C will make it easy to check the fluid level and topping up.
FYI Roadbend are the only Jag wreckers in Perth now. Jag Wreck and Aussie Jag wreckers closed down ages ago and getting Jag bits is now no longer an easy thing to do. Years ago you couldn't give an XJ6 away and now they are like hens teeth to find!
9 years 2 weeks ago #138683
by grahamjb
Lengthened the brake pedal/booster shaft to compensate for the shorter input shaft on the new M/C by turning down a bolt that happened to have the same diameter as the shaft...
Shaft lengthening photos
Painted and ready to fit
The other issue that is doing my wife and sons head in is that they don't like whitewalls and I reckon they suit the car...so here is a photo of what I want to fit (courtesy of Armadale Auto parts)
What do you think?
What do you think?
9 years 2 weeks ago #138684
by atkipete
Replied by atkipete on topic Re: International AR-110 Ute
Looking good, can you post a photo of how the new MC looks in situ. I am thinking of changing the one in my Dodge and have been told a Gemini one will suit.
Also an AR110 ute with a difference here www.flickr.com/photos/46046969@N03/16937059956/
9 years 2 weeks ago #138685
by dieseldog
Replied by dieseldog on topic Re: International AR-110 Ute
Yep, go the whitewalls...
- Thank you received: 4748
9 years 2 weeks ago #138686
Replied by Mrsmackpaul on topic Re: International AR-110 Ute
9 years 2 weeks ago #138687
by fxs80
1939 D2
Replied by fxs80 on topic Re: International AR-110 Ute
Well that's really rare, a wife that's wrong for a change
No really, Whitehall walls with cleans skins every time
1939 D2
9 years 2 weeks ago #138688
by fxs80
1939 D2
No really, Whitewalls with cleans skins every time
1939 D2
Time to create page: 0.607 seconds
