Rebuild of AT4114
10 years 7 months ago #125643
by AT4114
Ok just a small update I was going to take the front sheet metal of today but was offered the use of an industrial pressure cleaner to remove years of greese and mud . I'm amazed at the amount of crap that came of it lol
http://i.imgur.com/7p4qI7G.jpg?2
http://i.imgur.com/rraYtzw.jpg?2
http://i.imgur.com/7qvAV24.jpg?1
10 years 7 months ago #125644
Replied by bparo on topic Re: Rebuild of AT4114
With my AR I figured that stuff that didn't come off with a pressure washer after 50 years wasn't going to come off in a hurry. My actions were to pressure wash it, sand any rough spots, liberally coat the lot with rust converter twice then paint it. That was the year of the Melbourne Commonwealth Games(2006?) and no problem areas have shown up yet!
Sometimes you can make yourself more work than you need to.
10 years 7 months ago #125645
by AT4114
Yeh after the pressure wash I thought to my self the chassis isn't to bad rust wise I mite take your advice and hit it with a 4 inch angle grinder with a wire brush attachment sand down rust convert prime/ paint then bobs your uncle. Thanks for your advice you've made up my mind as its going to be my daily driver
10 years 7 months ago #125646
by v8 inter nut
Replied by v8 inter nut on topic Re: Rebuild of AT4114
Cab removal... Unbolt the doors first then take of the front clip off, I like to take as much off as possible the steering colum can be tricky but when you think it through the whole job is pretty easy just keep un bolting and lifting
10 years 7 months ago #125647
by AT4114
Thanks inter for the advice I've been watching your posts especially the pictures to see were you have unbolted the panels basically it's a big meccano set lol cheers mate
10 years 7 months ago #125648
by AT4114
Ok a small update not much done this weekend I had to clean out the shed to make room for the dodge . Anyway a mate lent a hand turning spanners the plan was to remove the diff and springs to clean them up and re bush the rear end only problem is how do I remove the pin at the front of the spring hanger ????? Any clues I will attatch a picture cheers Bryant
http://i.imgur.com/a0r2grf.jpg?1
10 years 6 months ago #125649
by IHScout
Dennis
Replied by IHScout on topic Re: Rebuild of AT4114
Hi AT4114, how did you go getting the pin out of the spring hanger? Not that I know how to help you anyway, but just hoping to hear that you made progress.
Dennis
10 years 6 months ago #125650
by AT4114
Hi scout managed to work out the shackel pins are keywayed with a roll pin then they are a press fit the only trouble is its hard to pull it out after 50 :-[ so a truck mechanic mate helped today . The way around this problem was to drill out the rivets that hold the shackel mounts to the chassis so they can be pressed out on a hydrolic press then I can re bolt the mounts with hight tensile bolts . I imagine the inter utes the same size would have the same set up i will post some update pictures cheers Bryant
http://i.imgur.com/yVh7pzj.png?2
http://i.imgur.com/IssHlFE.jpg?1
http://i.imgur.com/wgGMtzn.jpg?1
10 years 6 months ago #125651
Replied by asw120 on topic Re: Rebuild of AT4114
G'day. The Inters actually have a quite different setup with greasable shackles. They don't like to come apart after 50 years, either! Looks like the same rails, though. And the curved crossmember looks the same. You will also find IH in the front cab mount brackets.
Cheers, ASW.
Cheers, ASW.
10 years 6 months ago #125652
This post talks about re riveting the frame.
www.hcvc.com.au/forum/YaBB.pl?num=1365153942/3
Trevor
Replied by on topic Re: Rebuild of AT4114
Trevor
Time to create page: 0.574 seconds
