Yoke for pull rod hand brake
13 years 11 months ago #28246
by 70499
&&1959 Mercedes L319
Yoke for pull rod hand brake was created by 70499
Hi All,
Re: 1958 Mercedes 319
A little help......
Looking for (20) yokes for my pull rod hand brake set up. Stainless would be nice.
I checked out a few places in Perth and on the net but no luck.
Has anyone seen theses and can point me in the right direction?
Also they have a Mercedes part number but they are no longer available
They are 70mm long- 20mm width and the hole is for a 8mm clevis pin.
Thanks in advance.
Cheers,
Brad
A little help......
Thanks in advance.
Cheers,
Brad
13 years 11 months ago #28247
by ray
Replied by ray on topic Re: Yoke for pull rod hand brake
Maybe try a boat building supplier, yacht rigging has similar yokes.
13 years 11 months ago #28248
Replied by mammoth on topic Re: Yoke for pull rod hand brake
yokes were a common item at one time but are rarely used these days, what with hydraulics and fly by wire. Stainless yacht fittings are nice but there is a risk of going broke. Similar stuff is used on veranda decks supplied in Bunnings?. If you need 20 you could attempt to copy the original by bending up strip steel, sweat washers on with solder before drilling. (solder is actually quite strong in shear) or for a more substantial job mill & turn them out of bar.
13 years 11 months ago #28249
by white9000
Replied by white9000 on topic Re: Yoke for pull rod hand brake
you might be able to use a yoke off a s cam brake booster.
13 years 11 months ago - 13 years 11 months ago #28250
Replied by on topic Re: Yoke for pull rod hand brake
Brad - Who have you tried? Flexidrive and Statewide Bearings come to mind as potential sources.
Then there's always eBay, too ..
shop.ebay.com.au/i.html?_nkw=clevis+yoke...sid=p3286.m270.l1313
Cheers - Ron.
Cheers - Ron.
13 years 11 months ago #28251
by 70499
Thanks all for the replies,
I tried truckine, teleflex, multispares, mb, hsy, and a few other compaines that the first companies suggested but no luck. Also tried a machinst who said thanks but no thanks.
Was keen on stainless but do people think this would fail under load?
The other option then I gather would be steel/zinc dipped.
Cheers,
Brad
Replied by 70499 on topic Re: Yoke for pull rod hand brake
Cheers - Ron.
Cheers,
Brad
13 years 11 months ago #28252
Stainless would be fine, but would be harder to work, the difficulty depending on grade. Welding stainless is for specialists due to migration of molecules creating weakness.
13 years 11 months ago #28253
Brad
Do you have a Blackwoods store over on the L/H side.
www2.blackwoods.com.au/infoBANKSearch.aspx?q=clevis
Only problem is no pictures on the site, have always been helpful in getting hard to find bits.
Trevor
Trevor
13 years 11 months ago #28254
by 70499
Thanks Trevor for the Blackwoods link.
I will check out their Osborne Park store on Monday during the daily grind.
13 years 11 months ago #28255
Brad
How did you go. find any yet.
Trevor
Trevor
Time to create page: 0.436 seconds
