185mm Inside Dia intake hoses
- makeminea2stroke
13 years 1 month ago #48002
by makeminea2stroke
185mm Inside Dia intake hoses was created by makeminea2stroke
Hi, Got amate with a 6V92 in a Austral Tourmaster looking for some rinforced intake hoses, need 3 X 185mm Inside Dia., 90 degree elbows.....1 X 185mm straight joiner, think they also calls these hump
Seems like an unusual size from my google efforts. But I really have no idea.
Anyone got any idea on sources or even what brand filter housing setup he might have?There is two of the on the Austral setup, he doesn't think it is Donaldson due to the sizes of the piping
Thanx
Glen
Thanx
Glen
13 years 1 month ago #48003
MakeYourz2Stroke
Try this on fir size
dynamic.donaldson.com/webc/WebStore/hier...y.html?section=10126
www.dnaparts.com/hoses.htm
[ch9787]
Replied by Swishy on topic Re: 185mm Inside Dia intake hoses
MakeYourz2Stroke
[ch9787]
13 years 1 month ago - 13 years 1 month ago #48004
Replied by on topic Re: 185mm Inside Dia intake hoses
It sounds to me like he's got standard 7" Donaldson intake hose, which is 179mm in metric .. but the old hoses have probably stretched a little.
There is very little by way of intake/aircleaner components here, that is of American or Aussie origin, that is not Donaldson.
Austral would almost certainly have used Donaldson, particularly on a Detroit.
13 years 1 month ago #48005
by kelvin12
Replied by kelvin12 on topic Re: 185mm Inside Dia intake hoses
G'Day All,
Many thanks for the replies here, I am the mate 2 stroke was asking about the intake hoses for. Been meaning to join this forum for a while now so finally did.
Donaldson don't seem list these hoses, checked this via local truck dealers here at Coffs. Primary pipe is 185mm (7-1/4) odd size. While secondary is 155mm (6"), this one seems OK from one of the links posted above from the US, but the 185mm is a problem. 7" is the closest to this one. Not sure the hose would stretch that far over the pipe, they are pretty solid to go that far.
> :-X
> :-X
13 years 1 month ago #48006
Kelvin
Welcome to the Forum
take the tube where the hose has to fit, to the 'U Bute air intake Hose Store' n try the 7" it should slide on with the help of a leading edge n sum soapy water
[ch9787]
Kelvin
[ch9787]
13 years 1 month ago #48007
by kelvin12
Bit hard to do with the 7" elbows. Nothing available here in Oz according to the people I have contacted, seems to be available in the US but not here for some bloody reason. 6" is OK. Still hunting locally but looks like an email to the US might have to be the go.
Dirk
Dirk
13 years 1 month ago #48008
Is the actual pipe O.D 185mm or are you measuring the I.D of the old hose? Like Onetrack said it could just be a stretched 7" hose.
Aero in Melbourne supply 7" 90
13 years 1 month ago - 13 years 1 month ago #48009
I've never come across 7
13 years 1 month ago #48010
by kelvin12
No definitely 185mm and this is at its minimum sizing its a rolled and welded aluminum tube but the elbows seem to be spot on that measurement as well. Can't see the elbows being stretched from 178mm to fit as this stuff is pretty hard. But then again I can't see a special order being made just for this odd size. I think I'll go with the 7" and flog the hell out of it to fit. The secondary pipe is rolled steel tube so 6" elbow is OK. Found a place, Qld. Diesel that stocks 7" and 6" so will give them a ring tomorrow. If all else fails then I'll have to make them up myself in fibreglass and lag it heavily. I can avoid the exhaust pretty easily so should be OK in that regard. Even been thinking about exhaust tube, mandrel bends or donut bends if they do 7" but I think that's also an odd size for them.
Dirk
Dirk
13 years 1 month ago #48011
by Bugly
Replied by Bugly on topic Re: 185mm Inside Dia intake hoses
Instead of trying to make the hose up to 185mm, why not adapt the pipe down to 175mm?
Time to create page: 0.492 seconds
