chain drive
9 years 4 months ago #151736
by DeeCee
Replied by DeeCee on topic Re: chain drive
Thanks for all the info. I have it labelled as 'mid 20s' so I guess I wasn't far off. I will make the other measurements and look for any stampings.
9 years 4 months ago #151737
by DeeCee
OK, so I've had another look at the old girl. Here is some more info:
Chassis rail size: 200mm x 75mm
Cross members: 2 x 75mm tube steel. Steel bar across under where seat would be.
Diff housing is covered in cast numbers: H98881 (RHS), 18794H (RHS), 18740H (Back), 18886H (LHS).
Wheel size: 685mm diameter. Tyre size is unreadable.
Height from ground to chassis rail top: 1000mm approx.
Engine No: 15076
Cast on engine: 437DA, also a W overcast with a T.
Number stamped on front left chassis rail: 911
P.S. I also found another of these Inter chain drive trucks. It's chassis number is 1088. Looks to be about the same model.
Engine No: 15076
9 years 4 months ago #151738
Replied by on topic Re: chain drive
DeeCee
Will get these checked to see if we can narrow it down for you.
Did you get some more pictures so I can also compare them.
Trevor
Trevor
9 years 4 months ago #151739
by DeeCee
Thanks, mate. No, I remembered the tape measure but forgot the camera. Will do.DeeCee
Trevor
9 years 4 months ago #151740
by DeeCee
9 years 4 months ago - 9 years 4 months ago #151741
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Re: chain drive
Hi,
Question without notice:
What preservative product/ solution/ compound has been applied to the metal in the above photo's?
They have been very careful with it's application, as none seems to have been wasted on the ground beneath.
It make the steel look like old bronze eh?
Ta in advance,
-b
Ta in advance,
-b
Last edit: 9 years 4 months ago by Bobsboy.
9 years 4 months ago #151742
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic Re: chain drive
Looks a bit like fish oil on top of the original rusty surface?
9 years 4 months ago #151743
by DeeCee
Beaver and BB,
The stuff we use on the trucks (and all machinery and even roofs) is called Rustmasters. It's a corrosion control product, UV stabilised and is an excellent sealer. I think our mechanic mixes a little marine varnish with it for some extra shine.
We've also used another product called Extrol. It's brilliant stuff. Not cheap,but good.
Their website is:
www.rustmasters.com.au/
Their website is:
9 years 4 months ago #151744
Replied by asw120 on topic Re: chain drive
I can confirm the Extrol is good stuff (my chassis came out of the bush - still as good as the day it was done 5 or 6 years ago, but it is not UV stable. (says on the tin)
Cheers, Jarrod.
Cheers, Jarrod.
9 years 4 months ago - 9 years 4 months ago #151745
by Intermodel63
Replied by Intermodel63 on topic Re: chain drive
It looks as if it still has the Inter 283 engine so could make it a 74-C the W overcast T is also on the inter engine. Tubular cross members were fitted to the HS-74-C but had the Hall Scott engine, could have had a swap or changeover of models. What plans do you have for her?
Graham
Graham
Last edit: 9 years 4 months ago by Intermodel63.
