- Thank you received: 928
L-Line (I/H) Motor Truck Service Manual (Trans)
9 years 4 months ago #152067
L-Line (I/H) Motor Truck Service Manual (Trans) was created by Dave_64
Hi, All.
Came across this reference to International Harvester 'L-Line' Motor Service Manual (Transmission) somehow. Downloaded it and covers the following,
I/H 3 speed manual,
Warner Gear T87D-H41B-T98,
Fuller F51/F51C-F52/F52C- F54/F54B,
Also,
Fuller 2-A-45 auxilliary,
Brown-Lipe (Spicer) auxilliary,
5531-6231-6231A-8031C-8031G.
Downloaded in Adobe Reader format.
It came with a proviso that states:- "Donated by John & Susan Hansen-For Personal Use Only".
Anyhow, if anyone would like an email copy, send a p/m and as long as we don't infringe any copyright, I'll pass it along. I can't post files, but can email them to an email address.
Has full teardown diagrams, but unfortunately NOT the actual part numbers. Also, these are OEM designations but there is a correlation to I/H's line setting part numbers.
I got onto it looking for the original 5 speed Fuller that had the two (Hi and Lo) reverses in the same box. I have only ever seen one of these type of transmissions, Camden Constuctions rebuilt either a bogie drive R190 or R200 as a float. Had the 6 cylinder Cat motor out of a Cat 12 Grader in it, even had the decompression lever coming through the firewall to aid starting.
Cheers, Dave 64
I/H 3 speed manual,
Also,
Cheers, Dave 64
Time to create page: 0.351 seconds
