- Thank you received: 58
Pressure Protection Valve
8 years 10 months ago #160645
by jimbo51
Replied by jimbo51 on topic Re: Pressure Protection Valve
Thanks Alex, I've edited your email address out so spammers don't pick it up.
Swishy,
What Kenworth call the dual air system was introduced in the late 70's to meet new ADR's, 35 I think then 38 for trailers
It completely separated front and rear air circuits on the prime mover with the E3 footvalve replaced by the E6. The addition of a spring brake inversion valve enabled the spring brakes to function like service brakes in the event of a failure of the rear service brake air circuit.
The most obvious change in the cab is the absence of the black Emergency Spring Brake Release valve and the addition of the yellow Parking Brake valve.
The half truck would have what KW referred to as a single air system, not to be confused with early versions of air braking that used a single line system.
Swishy,
8 years 7 months ago #160646
by adb
Replied by adb on topic Re: Pressure Protection Valve
8 years 7 months ago #160647
Replied by Swishy on topic Re: Pressure Protection Valve
AdBlu
flop it out on the counter @ Kenworth
n C wot they tell U
other than th@ carefully pull it apart ..... n it might have a rubber diafram th@ can B recut from sum new u bute synthetic sheet if it haz a hole in it to leak the air
n C wot they tell U
8 years 7 months ago #160648
by adb
Hey swish....
Think it may be a pressure protection valve......i 'think'....not sure.... i googled the serial number....that's what came up....a haldex/similar pressure protection valve....
Time to create page: 0.409 seconds
