volvo n12 issues
11 years 7 months ago #93399
by Rapid
volvo n12 issues was created by Rapid
Hi all, i have been tidying a 1985 n12 up over the last twelve months,finally nearing the endjust a few hurdles now if anyone can shed some light would be great.
1. brohms brake valve in cab on start up leaks can only build pressure if held in
2. when driving their is a clonk in the frt end could this be spring pins or bushes.
3. the valve on the crossmember behind gearbox is leaking air out the exhaust port is it linked to a leaking brake booster on the frt diff
a few other issues will post later.
Cheers Rapid
Cheers Rapid
11 years 7 months ago #93400
by Debo
Replied by Debo on topic Re: volvo n12 issues
Straight away i'd say problem 3 is causing problem 1.
11 years 5 months ago #93401
by Rapid
Replied by Rapid on topic Re: volvo n12 issues
Hi All, does anyone have a diagram of the the fuse box on a n12
11 years 5 months ago #93402
Replied by on topic Re: volvo n12 issues
Hi Rapid ,please check your personal email thanks
Time to create page: 0.462 seconds
