Cargo brakes
11 years 4 months ago #100939
by Rapid
Cargo brakes was created by Rapid
Brakes on my cargo arent the best when loaded peddle is fairly hard, just wondering if the booster isnt doing its job,also if you smell the brakes does it mean they are fried
11 years 4 months ago #100940
G'day Rapid.
Ford Cargo's were just D series Fords with a Different Cab...
I've spent a fair Bit of seat time in 2 different D series...
With All due respect.
Your Post describes Perfectly the Brakes on those 2 D series Trucks..
Replied by hayseed on topic Re: Cargo brakes
G'day Rapid.
11 years 4 months ago #100941
by atkipete
Replied by atkipete on topic Re: Cargo brakes
The brakes should not smell in normal driving, check and see they aren't dragging.
11 years 4 months ago #100942
by waynestr
Replied by waynestr on topic Re: Cargo brakes
I have driven a few Cargos from new over a 4 year period (air over hydraulic),and to describe them as rubbish is a gross understatement. They were much worse than the D series. My right knee still suffers from the affects of the hard brake pedal. The ones with full air had wedge brakes, Need I say more?
11 years 4 months ago #100943
by ianlind
Replied by ianlind on topic Re: Cargo brakes
G'day All,
My new/1990 Cargo 2421 had good brakes up until a couple of days ago. Had a rego check a couple of days before Chrissy and no problems. A few days ago after sitting around unused, it developed and air leak in a valve block ( distribution Valve? ) near the dryer and I need to get a kit or a replacement valve unit. It has 4 piston valves in it and a couple of the seals are a bit pear shaped instead of round. I reassembled it with the lumpy sides of the seals against the body of the seat away from the ports thinking it might work, but it was only marginally better, so it's RS!
Any clues please?
Ian
Any clues please?
Ian
Time to create page: 0.388 seconds
