TE20 Tractor - Help
- farmerdave
14 years 8 months ago #12685
by farmerdave
TE20 Tractor - Help was created by farmerdave
G'day, I am writing this unbeknown to my frustrated husband who is slowly restoring an old TE20 Grey Fergie. This old tractor runs as smooth as anything - for the first half hour, then coughs and splutters etc after she warms up. My husband has renewed the coil, new carby kit, new fuel lines, new plugs, new radiator, but still it only runs smoothly for half an hour and then just starts missing and farting. He lets her cool down and away she goes again for a while and then no good again. Any suggestions? Have asked a couple of old farmers around the ridges, and no help so far. Any suggestions welcome. Thanks, Farmer Daves wife...
14 years 8 months ago #12686
Farmer Daves wife
Gudday Mrs
I aint no xpert
but thru a process of ilimination, problems @ times, can n do get solved
SO the
Replied by Swishy on topic Re: TE20 Tractor - Help
Farmer Daves wife
Gudday Mrs
I aint no xpert
SO the
14 years 8 months ago #12687
by HeyCharger
Proud owner of;
1948 Massey Harris 44K.
1946 Ford Semi-Trailer Bus.
Replied by HeyCharger on topic Re: TE20 Tractor - Help
Hi FDW. Welcome to our site. Sorry I cannot help with your problem, but you may also wish to post here;
www.ytmag.com/cgi-bin/boards.cgi
under the Harry Ferguson thread.
Wish you luck. Regards, Rod (MH44K owner).
Proud owner of;
14 years 8 months ago #12688
by HeyCharger
Or if you are a chicken like me , before the engine is started, pull back the spark plug lead insulating cap and then when the engine is running, just short out the plugs, one at a time, with a screwdriver.
Saves getting a belt to upset your heart pacemaker Rod.
Proud owner of;
Some spark plugs break down when hot
if u're game
with the engine runnin eratically remove a spark plug leed to hear any difference in the tune of the engine
do each plug seperatley n replace b 4 removing next leed this could/would tell U the cylinder # of the culprit
Proud owner of;
14 years 8 months ago #12689
by kennymopar2
Replied by kennymopar2 on topic Re: TE20 Tractor - Help
the condensor could need changing ..last year my old mans fergie had overheating problems..when i took the head off it had massive corrosion in the middle of the head sealing surface .. these old toys are getting old unfortunally
- farmerdave
14 years 8 months ago #12690
by farmerdave
Replied by farmerdave on topic Re: TE20 Tractor - Help
Okay, firstly, thank you all SO much for your replies, and yep I reckon we will get to the bottom of this if it is the last Fergy on earth. WE WILL NOT BE BEATEN!!!
No, not the condenser, its been replaced.
There is no water in the sump, so the head must be OK.
Have checked the plugs, and taken leads off one at a time and seems to be no problems.
If the head was cracked, wouldnt there be water in the sump??
We have had this tractor for about 2 years now and it has always done it. Most of the time it gets parked out of sight, because he just cant stand to even look at it drives him absolutely nuts trying to get it right, and is now suggesting a box of matches and a gallon of petrol, which will really fix it!!!
So, come on you guys, get your thinking caps on. I would love to see him happily choofing around on this thing, instead of swearing at it.
Regards, FDW
Regards, FDW
14 years 8 months ago #12691
FDW
GuddayMrs
Sme again
RE: If the head was cracked, wouldnt there be water in the sump??
Not nessesarily
a small crack in the combustion chamber of head will let water in n may B make it missfire
or leaky head gasket weepin into combustion chamber
should B noticable by a different colored sparkplug @ the bizzness end
Hay
But Wot do I no
I'm only a steer n wheel attendant
so they tell me
[ch9786]
FDW
GuddayMrs
Sme again
Not nessesarily
Hay
But Wot do I no
so they tell me
[ch9786]
14 years 8 months ago #12692
by ray
Replied by ray on topic Re: TE20 Tractor - Help
G'day FDW, You say the coil has been replaced, but is it the right one? Coils of the type that need a resistor to drop the voltage can overheat within a half hour and cause problems if they are used on a straight 12 volt system. I have had this problem myself, the coil became so hot it could not be touched. Ray
14 years 8 months ago #12693
When all else fails
clik here
www.bareco.com.au/files/geninterest/hfclub/hfclublinks.htm
www.greyfergie.co.uk/pblang/index.php
www.greyfergie.po.gs/phpBB3/
[ch9786]
When all else fails
clik here
[ch9786]
14 years 8 months ago #12694
Had email from AtkiPete
Hey Swishy,
I am lost in cyberspace at the moment, had some computer problems and now can do everything except log onto the HCVC forum. Something to do with my security settings Bruce thinks.
Now can you suggest to that lady with the Fergy to check the dizzy cap, especially the centre contract.
Had that problem on a car once.
Cheers Pete
[ch9786]
Hey Swishy,
Cheers Pete
[ch9786]
Time to create page: 0.556 seconds
