- Thank you received: 51
The 1418 Benz lookalike project.
We have even removed the cab rear support assembly and shock absorbers.
We have fitted the new L plate reinforcement to the out side of the chassis.
- Thank you received: 4778
Looking good Geoff and crew
- Thank you received: 1174
How do you prep the rails just with a wire brush on the grinder, or do you sand blast them
they do look as new when you are done.
i have an old lendlease chev that had the double rail and they got pitted bad in the gap.
i ground off the rivets and cleaned it all but the pitting is quite visable still. just wondering if there are any tricks to make them look better.
Jim
wombat 46 wrote: looking real nice!
Jim
If your never gunna do big loads I would just use bog and sand it back
I use a 4 inch angle grinder with a 5mm thick grinding disc to remove the bulk of the rust. I then smooth it with a flapper disc, as these wear down you can get an almost mirror finish on the surface you are sanding. The reason the chassis looks so good on the outside is because the L plate reinforcement is new.
We have been thinking if anyone else was left with the task of putting all the truck parts together that are sand blasted and primed and ready for reassembly, they might be a bit confused. Be a bit hard to fit these tail shafts and airtanks into this chassis.
thanks also for the tips,
i am starting to loose track or all your projects going side by side!!
A credit to all involved
Jim
I am 73, retired and have lots of spare time. My son, John and I have a flexible arrangement, generally I do the slow tedious (unskilled ?) tasks like pulling things apart and cleaning them up for repairing or painting which does not require being young and fit. I can do a lot of this sitting in the shade. As mentioned in the posts about the fuel delivery tanks, I do the 'scrounging', organising supplies etc.
John works full time and does the skilled work, welding, panel work, painting and reassembling. We feel this is the best use of his limited spare time.
It would be very difficult for one person working full time to spend the same number of man hours each week restoring something, as we can working together as a team on our projects.
As for the kegs, ???????.
Geoff.
:lol:
:lol:
Well
There not gunna MT themselves
:lol:
ยง
