- Thank you received: 539
CAV SL5 Starter Motor
6 years 10 months ago #184804
by Oilman
CAV SL5 Starter Motor was created by Oilman
I am currently repairing the starter motor off the Gardner. It was working, but the teminal bolts were rusted badly, and couple of the other connectors were frozen and couldn't be undone and some of the wiring was a bit frayed. Does anyone happen to have a manual or exploded diagram for one of these?
6 years 10 months ago #184809
by paulc20
Replied by paulc20 on topic CAV SL5 Starter Motor
This mob is selling pdf downloads.
www.marinepowerservices.co.uk/manuals/ca...otor-workshop-manual
6 years 10 months ago #184811
by paulc20
There is some useful info on the starters here:
www.gardnerengineforum.co.uk/Web%20PDF%2.../Newsletter%2014.pdf
The following user(s) said Thank You: mercskeepmeinajob, Oilman
- Thank you received: 34
6 years 10 months ago #184834
by mercskeepmeinajob
Replied by mercskeepmeinajob on topic CAV SL5 Starter Motor
Oddly enough I am currently trying to coax a Simms 12volt starter to do its stuff on a Guy Arab the link to the manual was most timely. Thankyou
6 years 10 months ago #184836
by ABCJOHN
Replied by ABCJOHN on topic CAV SL5 Starter Motor
I should have both on it and probably a parts list if the ID tag is still there at the terminals and readable.
i assume it says SL5 on that tag as most I've seen were either BS5 or BS6 strap on(probably older) and info would be different.
If you can put up the numbers I'll see if I can match them. Type and Des No
John
John
6 years 10 months ago #184846
by ABCJOHN
6 years 10 months ago #184850
by Oilman
Replied by Oilman on topic CAV SL5 Starter Motor
Thanks John, that helps. I have sent you a PM.
