- Thank you received: 4
d5n gearbox
6 years 6 months ago #188094
by trucksyd
d5n gearbox was created by trucksyd
gday , ive got a d5n dodge , 245 hemi ,4 speed gearbox , which i have just got back on the road recently . it was off the road for over 10 years ,& its quite hard to change the gears . does anyone know where the linkages are for a bit of grease ..thanks
6 years 6 months ago #188097
by trucksyd
Replied by trucksyd on topic d5n gearbox
does that mean they dont need to be greased ? ..im only familiar with the car linkages that mount on the side of the gearbox .
6 years 6 months ago - 6 years 6 months ago #188102
Replied by Dave_64 on topic d5n gearbox
Trucksyd, s'pose we should have clarified it for you, the Dodges that came off the production line 1961 on or so would have had the New Process 435 as standard, huge cast steel box with an alloy top that the gearshift lever went straight into. Would think that any that had a side linkage setup would either be a retrofit or something. As John K says, rip the top off and check for rust on the selector shafts, taking it that you have already checked the condition as well as the level of the oil? My books tell me to use either SAE 30 or 50 engine oil. If you go to the trouble to lift the top off, make sure the little nylon slippers are still on the tips of the selector forks, or not worn out. Last one I rebuilt gave trouble on the bench with hard shifting, combo of crook detent springs and balls in the selector shaft housings. That and like a DH, had two covers apart on the bench at the same time and mixed selector forks up, one Dodge, one Inter, very subtle differences between both. Dave
Last edit: 6 years 6 months ago by Dave_64. Reason: spelling
The following user(s) said Thank You: trucksyd
6 years 6 months ago #188105
Replied by Swishy on topic d5n gearbox
in the 1st instance
eye'd B inclind to push down hard on the gear lever
n put sum slip in where the lever goes in to top of selector
oil or grease dun matter
Nothing Ventured ............... nothing gained
ยง
ยง
6 years 6 months ago #188112
Replied by JOHN.K. on topic d5n gearbox
You can pull the gearstick out by simply pushing down hard on the tin cap,turning 1/4 turn to left,and lift out stick and retainer. Opposite to install.If you pull the box to bits,there is a bearing stack to be maintained,set by paper shims under the rear cap.If the taper roller is sloppy,remove paper shims ,no preload though,just eliminate slop.
6 years 6 months ago #188113
Have to agree with you John.K, really are a very simple box to dismantle once you do them a couple of times. Added beauty of them is that you can still get just about any parts for them, just may have to get a few hard-to-get hard parts from the States.
6 years 6 months ago #188121
by trucksyd
Thanks for your help gents , I,ll start by taking the top cover off & having a look , the shifting itself is ok , it just feels a bit tight from not being driven in many years , I have had it back on the road since June after being off the road for many years , I have had the engine recoed ,also the clutch & machined flywheel . I take it for a drive once or twice a week .
Time to create page: 0.546 seconds
