dodge truck engine
14 years 4 months ago #20042
Replied by on topic Re: dodge truck engine
big dodgy - grab a couple of cans of spray-on oven cleaner (Crazy Clarks usually has the cheapest) .. wear a mask, and spray the stuff anywhere the grease is thick. If ya wanna save any paint, you'd better not use it where the paint is, 'cos it will strip paint better than any paint stripper. Don't breathe the fumes, the stuff will strip the lining out of ya lungs, too ..
Once you've left the oven cleaner for 10-20 minutes, hit the area with the pressure cleaner.
If there's grease still there, after the pressure cleaner has done its job .. allow the area to dry, and hit it again with the oven cleaner .. then again with the pressure cleaner.
I use a little el-cheapo (275 bucks) 1400 psi, Eye-Tie pressure cleaner, that runs off a standard 10 amp plug, and it works a treat. You can get 'em at any decent hardware store or tool store. Don't buy the ones with plastic pumps, they're "consumer" crap.
Time to create page: 0.362 seconds
