Diamond Reo, to be or not to be??
13 years 4 months ago #42987
by norcoast
Diamond Reo, to be or not to be?? was created by norcoast
Hello, newbie here. Excellent site you have here, partly to blame for my next project. I have restored numerous cars and tractors and i think its time to move onto a truck. I have found a reasonable 70'
13 years 4 months ago #42988
by ray
Replied by ray on topic Re: Diamond Reo, to be or not to be??
G'day norcoast and welcome to the forum. You will get plenty of advice here, maybe not all good. About the only rule here is we need pics and plenty of them. There are clues at the top of the page on how to upload pics. As far as I am aware the number of wheels has nothing to do with going onto club rego.
13 years 4 months ago #42989
Replied by bigcam on topic Re: Diamond Reo, to be or not to be??
Hi Norcoast, it maskes it easier if you put where you are. It doesn't matter how many axle's in Queensland for club rego, you can even do a Road Train.
The 504 Cummins V8 185, will more than likely have electrolisys in the liners and will be cactus. You can get reasonably good 10.00 X 20 tyres from the wreckers for around $100 each, and then put 2 new 11R's on the steer, under $300 each.
Sounds like the truck needs a motor, and a good little V8 185 Cummins won't be easy to find.
13 years 4 months ago #42990
by melonreo
Replied by melonreo on topic Re: Diamond Reo, to be or not to be??
if there is a crappy little V8 cummins in there ,, you can pi$$ it off and put a 6V53 jimmy -end of problem
13 years 4 months ago #42991
Replied by bparo on topic Re: Diamond Reo, to be or not to be??
no problems with club reg here in Victoria either but you will need a roadworthy
13 years 4 months ago #42992
Replied by on topic Re: Diamond Reo, to be or not to be??
Could also be liner seals,has the coolant been kept up to it?Or put a crappy little 6v53 in it if you dont mind getting migraines
13 years 4 months ago #42993
by kenny-mopar
Replied by kenny-mopar on topic Re: Diamond Reo, to be or not to be??
would a 903 bolt into where a little 504-555 once was ?
just a thought ..
just a thought ..
13 years 4 months ago #42994
by newto
NOPE!!
Replied by newto on topic Re: Diamond Reo, to be or not to be??
just a thought ..
NOPE!!
13 years 4 months ago #42995
by newto
most common problem with water in oil is liner packings.if its sat for a long time without starting it could also be oil cooler orings.
cummins v504 is 210 hp and was the better of all the small v8's.......the older 185 was only 470cu in.
a cummins head gasket wont give you water in the oil so best method is drop the sump and pressurise the cooling system....if the water drips from behind the liner its the packings,if it drips inside the liner between the piston its a pin hole from electrolysis,if it drips out the main bearing caps its oil cooler.
hope that helps,
newto
However the engine gets water in the oil, which could be just a head gasket or at worse a cracked head or liner.
1010033 P1010033-2
hope that helps,
newto
13 years 4 months ago - 13 years 2 months ago #42996
by norcoast
Replied by norcoast on topic Re: Diamond Reo, to be or not to be??
Hi again, thanks for all the information, looks like its going to be a bit of a gamble between electrolisis destroying the block or just a few O rings on the oil cooler. If it is terminal I still think I will stick with the deep rumble of the V8 Cummins. Its hardly going to be driven so I dont want to spend too much on the engine.
I managed to post some pics on flickr, addy is:
www.flickr.com/photos/norcoast
Last edit: 13 years 2 months ago by bigcam.
