Diamond Reo, to be or not to be??
keep on truckin-des
if you've checked all that and its still slow to return and its got the tacho shaft mount in the main body then where the cable goes pack it with grease.
let me know what you find,
newto
as in newto onetrack!
Only problem now is that im out at work for another 3 weeks and I cant try anything
hey newto dus your surname start with O
hmmm....i'm a little slow.....not sure i got that?
thinkin' maybe too much info in one hit?
Thanks for the info BigCam/Truckin-des/newto, sounds logical as i noticed air pockets in the temporary clear plastic fuel return line, so the air was commin from somewhere?
bubbles in the return are normal....cant remember exact figure but something like 70% of the fuel from the pump to the injectors is used to cool the injectors so you'll always get air mixed in with the returning un-used fuel.
newto
absolutely no offence meant
sorry about that newto the onetrack part was only because you pair are extremely (to me) knowledgable and good value to the forum .
maaaate,
i didn't take offence nor thought you meant any........i've probably had 1 too many sherbets tonight and answering many emails so just didn't think it thru totally......all good :-[
newto
Detective, ya can't beat newto when it comes to Cummins! I reckon the man must sleep with Cummins manuals for pillows!!
nahhhhh......i like soft pillows.....and grease free!!!
