- Thank you received: 47
KW chassis and Cummins 903 engine number locations
13 years 1 week ago - 13 years 1 week ago #51082
by paulc20
KW chassis and Cummins 903 engine number locations was created by paulc20
Looking at getting the safety inspection for rego soon. The inspectors have asked that I make sure the numbers are visible,, so where is:
1/. Cummins 903 engine number?
2/. Kenworth K145 chassis number?
They think chassis number may be on right rail ahead of where the aluminium joins the steel, but not sure.
Thanks
Thanks
Last edit: 13 years 1 week ago by paulc20.
13 years 1 week ago #51083
Replied by on topic Re: KW chassis and Cummins 903 engine number locations
PaulC20 - The Cummins 903 S/N is on the dataplate on the rocker cover. If this dataplate is missing, the engine S/N is stamped in the block, on the LHS (starter side), just above the sump/block join line.
Where's GM Diesel when we need him, with his recently-rebuilt 903?? .. :
13 years 6 days ago #51084
by paul404
Replied by paul404 on topic Re: KW chassis and Cummins 903 engine number locations
The 903 engine number is a 8 didget number stamped into the block behind the left head as ron said.
13 years 5 days ago - 13 years 5 days ago #51085
by GM Diesel
Replied by GM Diesel on topic Re: KW chassis and Cummins 903 engine number locations
Hi Paul,
The boys are right with the engine number being at the back of the left head on the block. Its near the oil pressure sender. It will either be stamped into the cast or in the case of the 903's in KW's a rivited aluminium plate 60 x 45 mm in size. HP, engine number and governed rpm are stamped on this plate also.
Your on the right track with the chassis number. Right side near the join.
Basil
Engine number position / tag on block just near cylinder
Basil
Last edit: 13 years 5 days ago by GM Diesel.
13 years 5 days ago #51086
by paulc20
Replied by paulc20 on topic Re: KW chassis and Cummins 903 engine number locations
Thanks everyone. Will get the degreaser and Gerni out tomorrow and hopefully find it.
The photo of the engine is great, should make it easy to find the number.
13 years 4 days ago #51087
by paulc20
I have found the engine number stamped on the block where you told me it should be, thanks.
Still looking for chassis number...
12 years 11 months ago #51088
by Baro
Replied by Baro on topic Re: KW chassis and Cummins 903 engine number locations
paul my 78 k124 number is on the r/h side about 8 to 10 inches behind the gear stick tower on the top of rail
rob
rob
12 years 11 months ago #51089
by 82cabover
livin the dream oldskool is cool
Replied by 82cabover on topic Re: KW chassis and Cummins 903 engine number locations
Gday Paul Baro is right the number on my 82 model is above the right hand rear spring hanger and is very faint cant see it since i painted chassis cheers Col.
12 years 11 months ago #51090
by paulc20
Thanks, was getting worried it was under the crane mounting. Will have another look in daylight before getting carried away with the stamps.
