903 Coolant and oil capacity, gearbox and hubs
13 years 4 days ago #51196
by paul404
Replied by paul404 on topic Re: 903 Coolant and oil capacity, gearbox and hubs
Hi Paul. work out how much coolant you need like Cam said, then buy the coolant premixed in 20l drums and fill. It used to be called complete 50.
Spin on a zero unit filter.
its a bit dearer but the guess work is taken out of it.
13 years 4 days ago #51197
by paulc20
Replied by paulc20 on topic Re: 903 Coolant and oil capacity, gearbox and hubs
It looks as if Castrol Premium Cool Plus 50 is direct equivalent to the Fleetguard Compete 50, same test kits, loaded with SCA for initial fill and compatible with fleetguard filters for SCA maintenance. Will check pricing tomorrow.
13 years 2 days ago #51198
by paulc20
As Paul404 suggested I bought Fleetguard Compleat 50, cost was less than the Castrol concentrate and didn't have to chase up demineralised water.
I put 40 litres in, level is in top tank of radiator but will need a bit more. I couldn't get a 0 unit filter so had to use a 4 unit filter.
Time to create page: 0.440 seconds
