Info need on Clayton Dewandre Brakes
15 years 7 months ago #4782
Info need on Clayton Dewandre Brakes was created by
On my 1936 Wide Body Bedford i have Vacuum brakes Type TV2/150RH i need help on how to service etc. Dave
15 years 7 months ago #4783
Replied by Swishy on topic Re: Info need on Clayton Dewandre Brakes
Dedly
Sme again
RE: i need help
YES U need all the help U can get!
n also with the brakes
Have been taken over by
Do U need parts ?
Or have U a problem ?
Where here 2 help the needy
n
not the greedy
Sme again
RE: i need help
Do U need parts ?
n
not the greedy
15 years 7 months ago - 15 years 7 months ago #4784
by Andy Wright
Replied by Andy Wright on topic Re: Info need on Clayton Dewandre Brakes
Dave, do you know Peter Morris? He's just finished a resto of a Super Hippo with those brakes and is pretty cluey anyway so might be able to help.
I realise the scale will be a bit bigger and the Leyland is more modern (!) but the principle's more or less the same. If you don't know him, give me a yell and I'll pass on his email and/or phone number.
Last edit: 15 years 7 months ago by Andy Wright.
15 years 7 months ago #4785
Replied by on topic Re: Info need on Clayton Dewandre Brakes
Andy,
Peter Morris's new toy has Air brakes not Vacum like Dave is talking about.
My Thornycroft also has Clayton Dewandre brakes. But again like Peters are Air brakes not Vacum.
15 years 7 months ago #4786
by Andy Wright
JB, interesting. I sold Peter a repair kit for the brakes. Goes to show how much I know about the brake set up compared to Dave's beast.
Given Peter's knowledge, Dave, it might still be worth asking him.
15 years 7 months ago #4787
by Rookie
Replied by Rookie on topic Re: Info need on Clayton Dewandre Brakes
Deadly,
I have Clayton Dewandre vacuum brakes on my 1947 Leyland bus which I'm about to tackle. I've got a workshop manual with some information, but I sent over to Old Blighty and purchased a manual from here
www.wallagereprints.com/classiccars.htm#clayton
I'm just not sure what to do if the leather seals are buggered.
Steve
Steve
15 years 7 months ago #4788
by GM Diesel
Replied by GM Diesel on topic Re: Info need on Clayton Dewandre Brakes
Dave, Steve
Ive just overhauled one for our club Albion and there not to bad to set up.
Honed vacuum champer with a ball hone. Made a new leather bucket with a male / female mold turned on a wood lathe.
Get some good quality cow hide and soak in water for a couple of days.
Place over male part of mold then push female over and pull up tight with a bolt through the middle. Make sure bold is true center of mold.
Leave to dry thouroughly (1 plus weeks ) then remove outer mold piece and reverse then bolt back together. Mount assemble in lathe with the bolt and spin up at slow speed. You can then trim outer edge of bucket true with a new razor blade while its turning. Under cut to create a good edge.
Reassemble on plunger. Works perfect.
Make sure you get all the mechanism parts within the servo assist linkage part of it back right during reassembly. Draw some sketchs of parts or use a book if you have when reassembling.
Dont forget to adjust servo opening valve on the outside of chamber when you get it back in and engine running. If its out of adjustment you will pick it up with crappy idling and very low or no manifold vacuum. This valve is under a little half round tin cover on the outside of the servo housing.
Barry
Barry
15 years 7 months ago #4789
Dedly
GuddayM8
have U tried PBR
PBR stands for Patent Brake Replacements
th@ means they have supplied parts for other makes etc
worth a ringy thing
or ABS
GuddayM8
have U tried PBR
worth a ringy thing
or ABS
15 years 7 months ago #4790
by Rookie
GM Diesel, thanks for the great advice. The ball hone you mention, is that the hone with lots of little flexible balls on it, what my mate refers to as a dunny brush? The outside diameter of the front wheel servo's measures close to 7" so I image I'm going to need a large hone.
15 years 7 months ago #4791
by GM Diesel
Yep dunny brush hone is the one.
Barry
Barry
Time to create page: 0.521 seconds
