air driven wiper motor problem
12 years 9 months ago #60826
by bus-ted
air driven wiper motor problem was created by bus-ted
Hi all, i have a 77' bedford bus and I am trying to sort an air driven wiper motor out. I have air getting to the motor but no driving is occuring. The air leaks out of a small pipe fixed to the bottom of the motor, placing my finger over this to block it does not alter the action of the motor. What are the main problems that occur with these motors?
12 years 9 months ago #60827
Replied by on topic Re: air driven wiper motor problem
Mate i would have to say that , originality aside..
Probably the best thing you could do would be to bin it and replace it with electrics..
Drove from Yass to Campbellfield in an old K100 one night in pouring rain with my head out the window.
The wipers worked once and that was it.
Bastard things. >
Bastard things. >
12 years 9 months ago #60828
Replied by bigcam on topic Re: air driven wiper motor problem
Quite often the exhaust "muffler" gets clogged up with a mixture of oil and dirt. No exhaust means the air can't flow through the motor. The exhaust "muffler" looks like a little aluminium cylinder about 12mm long and about 10mm round. If you take it out the wiper will work, but it will go flat out, because it also provides a bit of restriction to keep the wipers at around the right speed.
12 years 9 months ago #60829
12 years 9 months ago #60830
by bus-ted
Replied by bus-ted on topic Re: air driven wiper motor problem
How do i go about matching up an electric equivalent?
12 years 9 months ago #60831
by Digger
Haha, great wipers in a KT 125.
You could spend hours trying to synchronize them on a rainy night trip from Sydney to Broken hill.
Keep you awake for hours.
Digger.
Replied by Digger on topic Re: air driven wiper motor problem
Bastard things. >
Digger.
12 years 9 months ago #60832
Replied by prodrive on topic Re: air driven wiper motor problem
Good question, Bus ted! Ok you blokes, while we are on the subject of air wipers-
My Mack has em too, They are hopeless, I agree, they either go too fast or stop and wont start, you know the drill!
So my question is, is it just because they are old and worn out that they are hopeless? Or are they born that way?
I can buy a NEW genuine air wiper motor for about $250 I think- but are they any good new? Or should I just ditch them and mocka in an electric motor?
Anyone got any ideas of which electric wiper motor would fit an R600?
Sorry for hi jacking your thread too, Bus ted......
12 years 9 months ago #60833
by bus-ted
Right, cleaned the wipers out completely today and got them to work once i get some decent air pressure up 4+ Bar. Think i put something in the wrong way though as i turn the lever left and the wipers spread and stop, i then have to turn the lever right to get them to come together again. Would be fun up hill, at night, in the rain, changing gears and turning the knob left and right
12 years 9 months ago - 12 years 9 months ago #60834
by Chocs
Replied by Chocs on topic Re: air driven wiper motor problem
air in the Transtar too...
they work...although i recall ol mate spent some serious cash on them..
i haven't driven anything with air wipers yet, that i personally would recomended..
Measure the sweep, take the unit out..head down to the wrecking yard and do a few comparisons...
Also after market, general purpose units for fork lifts and loaders are a real good option too..
chocs
chocs
12 years 9 months ago #60835
take it easy .....all air tools need to be lubricated and these things are no different. take the air line off the entry (air in) and put some sewing machine (or any) oil in...but at full air pressure on the gauge.... it will usually fix the immediate problem but the real culprit is moisture in the air system that will gum up the tolerances built into these things. solution is to DRAIN YOUR AIR TANKS DAILY..... let alone a buggered compressor, air leaks or mal-adjusted wiper switch (by the way gives you variable speed for operation) . .....mack air starts (ingersoll rand) have had for years self oilers to assist this very problem ..
Time to create page: 0.508 seconds
