- Thank you received: 91
Calling Volvo experts - N12 cooling
10 years 1 month ago - 10 years 1 month ago #132512
by Bobsboy
Mucking about on the edge
Replied by Bobsboy on topic Re: Calling Volvo experts - N12 cooling
Ya?
Now I remember, I had boiling coolant out of the header tank too. . . (used a big coke bottle to catch some of it).
it couldn't be could it?
Bloody Europeans. >
I feel your pain. :'(
-b
Cummon Swishy, what's the answer here?
Bloody Europeans. >
-b
Last edit: 10 years 1 month ago by Bobsboy.
10 years 1 month ago - 10 years 1 month ago #132513
Replied by mammoth on topic Re: Calling Volvo experts - N12 cooling
The earier motors had multiple thermostats, one of which opened an internal bypass. Yours probably has a variation on that theme. I would be testing the external lines to the
1/compressor
2/engine oil cooler
3/gear box oil cooler
for blockage as relatively easy to do and can then be ruled out.
Given that pressure rises with engine speed and there is no oil, the compressor must be a suspect for air leakage into the cooling system. (maybe bypass the compressor cooling or open pressure governor setting so compressor is making no pressure as a test?)
1/compressor
2/engine oil cooler
Last edit: 10 years 1 month ago by mammoth.
10 years 1 month ago - 10 years 1 month ago #132514
Replied by jon_d on topic Re: Calling Volvo experts - N12 cooling
I know nothing about Volvo's....
but from the symptoms, this would be my take.
1. On the long down hill run, the radiators working and cooling the water in the radiator; and the engine is not developing heat. So, the themostats are closing and effectively blocking the pressure release path. (or severely constricting the path compared to the volume of gas being pumped.)
2. Under load, the thermostats would be open and water circulating. Thus any pressure will vent via the radiator cap. It would look like the system is pressurised. Which it is, but the pressure is caused by gas and not by the expansion of coolant under heating.
Q: does the overflow tank show signs of being flooded or had the lid popped off or something?
3. I don't think it's oil caused because the volume of the oil needed to build extra pressure would empty the sump over time. (and note, no oil was in the coolant.) The comment about the presure tracking oil pressure supports the idea of a compression leak. The pressure is tracking RPM's. Just like the oil pressure.
4. Running on an exhuast brake would have similar compressions (or less) as driving under load. (consider ignition pressures) which brings me back to point 1 and 2.
Based on the 4 points , I reckon there is pressure pathway from a chamber to the water jacket. And, the leakage would be noticeable all the time if you were looking in the right spot. But, the spots will change depending on what the thermostats are doing. (and that's why there are confusing symptoms)
Q: Have you measured the radiator pressure at the cap while under fast idle speed with the thermostats open? My bet would be that it increases to bust pressure or the cap release pressure.
Another idea would be to extend the overflow hose into some sort of loop and watch for bubbles as the radiator cap releases.
A leakdown test is probably the only way to find out which pot is shot. And, probably necessary and the least expensive method if something is cracked. btw, test all pots, even if the first one is shot.... there may be more than one gone.
One last question, again this is because I know nothing about the engine, is the exhaust manifold (or turbo??) water cooled? There may be a crack in these and it's pressurising when the brake is closed. (again, I assume we are talking about an exhaust brake and not a jake,) If they are, then, it may be possible that its being pressurised "outside" of a combustion chamber. If they are cooled, then the leakdown will show nothing and you'll need to prove 'idea' by pressuring the exhaust somehow.
jd
jd
Last edit: 10 years 1 month ago by jon_d.
- wedgetail84
- Thank you received: 49
10 years 1 month ago #132515
by wedgetail84
Replied by wedgetail84 on topic Re: Calling Volvo experts - N12 cooling
OK, hay again today so no progress. But the compressor idea sounds reasonable, I'll bypass it and see what the pressure reading is. I don't see how it could be either tranny or engine oil cooler due to the clean coolant.
The exhaust brake (not jake) has no cooling lines.
Jon_d, nicely surmised, and all points lead to a leak down test really. Hopefully I can pop the bonnet on monday!
Time to create page: 0.435 seconds
