- Thank you received: 4
Twin gas research
Minus converters etc etc
i87.photobucket.com/albums/k141/bwtrench...CCB3_zpsvd5kwtth.jpg
- Thank you received: 1191
I read comments with interest. I have been playing with LPG for nearly 30 yrs, yes some systems leave a lot to be desired, & that applies to some technicians fitting up the rocket as well. A fine example of an engine that performs well on the bbq ring as we call it, is the Ford dedicated engine, correct compression ratio, cam overlap etc.
The old Impco 425 mixer will feed most applications, & you will be able to draw a huge amount of vapour through a Impco E convertor.
My experience with gas powered engines, even today, NO ONE will utilise a 5 gas exhaust gas analyser to determine an engines combustion efficiency. Yes there are oxygen sensor type Air Fuel ratio meters, however, they do not give you the true picture of what is happening in the combustion chamber.
The price of LPG in your area will determine if it is worthwhile or not. I noticed the price in Geelong yesterday was 50.5 a litre, petrol a 1.35. Let you do the sums, if on average, an engine on impco system, if running correctly, will consume approx. 10% more, if running correctly, tuned properly etc.
Happy to help advise if required.
Gilly
I take it from your explanation Gilly that this is the reason Falcons were popular as taxis? Best car to do big K's on gas?
