- Thank you received: 839
Shortening a jackshaft
I used to be a truck driver,
on a good day i can remember
- Thank you received: 4768
dno wrote:
Dave_64 wrote: Like This, gives two different MAX angles for two different lengths,
Is that measured between the two faces OR the MAXIMUM inclination (or slope)
of the shaft??
Dave
the last tail shaft shown here is ok even though have it marked as not ok
All PTO shafts on trailing farm implements have this arrangement when they turn a corner and last for ever and a day
As long as the angles are equale and the uni crosses are in line they work fine
People say the tail shaft cant be dead straight as the uni's wont lubricate I dunno how true this I think if they were dead straight they would never have a need to turn so it would be fine
However if it was only a poofteenth off I think thats when you would have a drama so its easier make them with a good angle so have plenty lubrication as they rotate around
Thanks Guys.
Dave
Think you'll find the max angle from the chart is more to do with clearance issues.
I had a very short shaft on my V drive setup. The yokes would almost bottom against it's mate due to the steep shaft angle.. In fact I made a mistake once when replacing the unis, and they fouled. Must have been a slight manufacturing difference one side of the yoke to the other and she wouldn't rotate smoothly.
Pulled her apart and refitted 180 out, all good.
- Thank you received: 34
of the shaft??
Dave
Not quite right Paul, even on farm implements the shaft on the implement is best set horizontal to the ground. Check the angle on the bottom shaft in the last pic.
The second Pic from the top IMO best represents a farm implement scenario.
Limited Access Excavations.
dno wrote:
of the shaft??
Dave
If you look at the draw bar from the seat on the tractor as in a birds eye view its like the last picture when you turn
The draw bar pin is the same measurement on all implements to the uni and the same to the PTO shaft on the tractor I think its 14 1/2 inches but could check
would knock like all hell on the baler when turning hard, now I use the tool bar on the lifting arms. Very little to no knocking.
