F65 Fargo kew flathead 6 workshop manual
6 years 7 months ago #187528
by MiniMark
F65 Fargo kew flathead 6 workshop manual was created by MiniMark
Desperatly seeking a plymouth, dodge, engine workshop manual and vehical owners manual for an F65 Fargo Kew...
6 years 7 months ago #187530
by grandad
Replied by grandad on topic F65 Fargo kew flathead 6 workshop manual
6 years 7 months ago - 6 years 7 months ago #187534
Replied by Lang on topic F65 Fargo kew flathead 6 workshop manual
Mark
Is that a KEW motor? Looks like a Plymouth motor with that engine number (used widely on other Chrysler 50's products as well as Plymouth). I think the C after the number is Commercial.
Will look in the book. Grandad's stuff is good as it looks like it applies directly out of the specs for your model (assuming they did not change the engine).
If the book says it had a KEW motor this is what the number looks like and you have a replacement.
Last edit: 6 years 7 months ago by Lang.
The following user(s) said Thank You: MiniMark
6 years 7 months ago - 6 years 7 months ago #187535
Just done some searching.
Your motor appears to be a late 1940's Canadian built Plymouth (That is what the "C" stands for after the number). Different from the specs in Grandad's chart.
It should be a 25 inch long block.
The bore is 3 3/8" and the Stroke is 4 1/16" it is 218 cubic inch - quite a bit less than a KEW.
Any Dodge engine book will give you 90% of the correct procedures for this engine you only need the correct specs for main measurements. I will see what I have in my manuals.
Here are the manuals to cover your motor on-line.
www.rockauto.com/en/catalog/plymouth,195...,repair+manual,10335
And here is the story of where your truck was built.
www.allpar.com/world/kew.html
6 years 7 months ago #187544
by MiniMark
Replied by MiniMark on topic F65 Fargo kew flathead 6 workshop manual
So you believe that a motor change was done to this Kew?
I was so confussed looking for info and this would make sense.
6 years 7 months ago - 6 years 7 months ago #187557
Sorry I have tried everything to get this up the right way.
It would appear so but I would not put anything past the Poms.
They might have put the Canadian Plymouth 218 motor(97hp) in the small trucks and the KEW 250 (135hp) motor in bigger ones. Engine changes on Dodges are easy (done a few myself) as nearly everything just bolts up and where there are differences (such as engine mounts for a particular vehicle) you can take the bits off the old one to just bolt to the new. Easy for me to say as you are trying to stretch a fuel line or an exhaust pipe an extra inch!
I would be guessing a change but still a real good old motor. Yours looks to be 1949 from the numbers
6 years 7 months ago #187561
by Rusty Engines
Replied by Rusty Engines on topic F65 Fargo kew flathead 6 workshop manual
Time to create page: 0.498 seconds
