- Thank you received: 242
Front axle loads
1 year 8 months ago #238672
by jeffo
Front axle loads was created by jeffo
Was sitting at the lights beside an 8-wheeler tilt tray.
AGM said 30t.
I did some sums and that must be about 13 or 14 ton on the steer group.
Seems a hell of a lot per tyre?
50 years ago we had 4t on the steer axle.
AGM said 30t.
1 year 8 months ago - 1 year 8 months ago #238674
Replied by Lang on topic Front axle loads
This lays it all out very clearly.
www.nhvr.gov.au/files/201607-0116-mass-and-dimension-limits.pdf
Last edit: 1 year 8 months ago by Lang.
1 year 8 months ago #238722
by overnite
Wasn’t that raised to 6t on the front axle many years ago?
Replied by overnite on topic Front axle loads
AGM said 30t.
- Thank you received: 839
1 year 8 months ago #238723
by BillyP
I used to be a truck driver,
on a good day i can remember
Replied by BillyP on topic Front axle loads
.The last Zacuba 8 wheeler that i was in (Ex Comet ) with load sharing steer axles got 11
on the steer and 16 .5 on the drive for a truck total of 27 .5 .............
That seems to tie in with that chart..............
Now that was with all sprung axles....... wot about running on air bags.. does that alter things ??????
.....................Billy.....................
1 year 8 months ago #238725
by jeffo
Replied by jeffo on topic Front axle loads
From Lang’s info it gets pretty close to 30t when load sharing plus other factors are included.
Just showing my age I guess.
Still a lot to ask on a steer tyre. Wasn’t those huge steer tyres sometimes fitted.
1 year 8 months ago #238730
by V8Ian
Replied by V8Ian on topic Front axle loads
Our tyre loads are quite modest, compared to European allowances.
1 year 8 months ago #238734
Yes It was.. You're Actually allowed 6.5 Tonne on the Steer if you have a late Model Truck fitted with a Front Under-run device &/or a Cab that meets Euro Crash standards.... (Page 4 of Lang's Link explains It...)
Replied by hayseed on topic Front axle loads
The following user(s) said Thank You: overnite
1 year 8 months ago #238737
by overnite
Thanks Hayseed, I thought I had recalled that correctly from many moons ago.
1 year 8 months ago #238756
by Brocky45
Replied by Brocky45 on topic Front axle loads
Is that why the use 2 axle tractors (prime movers) to pull 3 axle trailers all the time?????I believe the standard Euro front axle weight is 8 tonne.
Time to create page: 0.434 seconds
