perkins has a mind of its own
12 years 5 months ago #67415
by paul404
Replied by paul404 on topic Re: perkins has a mind of its own
Not sure how it's set up, but it could be sucking oil from the timing case into the injector pump through the seal in the front of the pump.
12 years 5 months ago #67416
by Kav
Replied by Kav on topic Re: perkins has a mind of its own
Hi all - What about the valve in the cold start/excess fuel container. I have had one of those to leak and pour fuel into the inlet manifold, which could account for the over- revving. A faulty key switch could also dump fuel into the manifold while you are going along. Best regards - Michael
12 years 5 months ago #67417
by Malfunction
Replied by Malfunction on topic Re: perkins has a mind of its own
My 5 cents worth, because 2 cents ain't used no more. Check the oil level on the stick, if its higher than it should be and nobodies put more oil in, smell the oil on the stick, it may have diesel leaked through to the sump, via the lift pump or like. (accounting for the running away)
Then the motor runs on almost the smell of an oily rag.
- Mike Moore
12 years 5 months ago #67418
by Mike Moore
1971 International ACCO &&1971 International 564 &&196? Nuffield BMC mini &&
Replied by Mike Moore on topic Re: perkins has a mind of its own
thanks for the input guys. ill check everything mentioned and hope its nothing terribly major. dont want it playing up on the way to sandown :-[
12 years 5 months ago #67419
Replied by Sarge on topic Re: perkins has a mind of its own
Mike, another 2 cents worth, and maybe thats all it will cost... The gunk in fuel filter you will have under control, the governor control my be as simple as the throtle return spring and or linkages.
The little arm on the side of the injector pump is grub screwed or clamped onto the shaft and you can change its angle if you want to... or it may have changed its self????
I rebuilt all those very basic shaft and pivot linkages from the pedal to the pump because its too sloppy and inclined to stick, then put a very long but soft spring onto the pump shaft to make sure she came back to idle easily.... much improved....
and then I went and spent my lifes savings and naming rights on three childen to get the pump overhauled (for a different reason).
good luck, see you at Sandown
/me
/me
12 years 5 months ago #67420
by Beaver
Beaver@ Museum of Fire
Replied by Beaver on topic Re: perkins has a mind of its own
We had a similar problem in an AEC diesel a few years ago. Turned out the fuel in the pump waxed up and prevented the rack from moving freely.
Cleaned that out and has run perfectly ever since.
12 years 5 months ago #67421
OK then
Wot damage is caused by the throttle linkage out of adjustment where by a size 9 held firmly on the go pedal, where the force is transfered to the innings of the said fuel pump
normally there is a safe way to get max on the throttle lever without gr8 force from the linkage
Ifn U get my drift
[ch9786]
Replied by Swishy on topic Re: perkins has a mind of its own
OK then
Ifn U get my drift
[ch9786]
Time to create page: 0.486 seconds
