detroit..screaming meanie (na not my missus)
- kennymopar2
cheers ken
A 6V53 if you drive it like you stole it and hot rod around you can get them down to 2.5 kms/liter. Drive with steady as you go throttle control and keep the revs up you can get good mileage.
The old 190 averaged 4.1kms/liter over the 8000km trip to Melbourne and back. Worked its ring out going over and went easy coming home.
Only thing wrong with a Detroit in a recreational truck is puddling around on club runs with no load.
After about an hour buggerising around at 40mph mine starts dribbling out of the exhaust manifolds and honking blue smoke out the stack.
Use good quality low ash <0.5%, straight 40 weight oil in them, keep them in tune. Clean fuel and air and they will last well. If you dont look after them properly they will go down hill real quick.
Basil
- kennymopar2
ps thanks for the perkins workshop manual
Good the manual got there.
I did around 500k's bobtail with the 190 last weekend and got closer to 5k's to the liter sitting on around 95kmh @2100rpm.
Seems to be its sweet spot around this speed.
The hardest thing these days is finding a 6V53 in good nick thats been looked after. Most ive come across are cheap or free coz there's something wrong with them.
Alldiesels in QLD normally have some decent ones in stock.
Basil
- kennymopar2
KeMoPa
gudday M8
RE: what do i need to look for when im looking at a 6V53
In a word
its life history
just like anything in life
If U spend too much for the beast n is realiable n dont cost U anything = cheap beast
if U get a cheapy n is unreliable n costs lots to keep it running = expensive beast
ButEyeDoSt&2BCorrected
screeemers have the added adavantage of haveing oil also on the outside
they mark out there own territory by returnin oil from where she cum from, good ol mother Earth
Screeemers do love revs
so U drive m az tho its stolen
pedal to the metal
[ch9787]
Hi allHey Ken it all depends on how you drive them.
Basil
The best oil, if ya can get ya mitts on it, is BP Vanellus DD40/DD50 - info here:
Vanellus DD40 and DD50
Low sulphated ash diesel engine oils formulated to meet the special requirements of the Detroit Diesel Corporation
- kennymopar2
Vanellus DD50 has been specifically formulated for use in Detroit Diesel 149 engines above ambient temperatures of 35
Manual - 7SE270 can be found at the link here : www.detroitdiesel.com/support/on-highway...ants_fuels_coolants/
What ever you do dont run DD-50 in a 53 series detroit...it'll bung it up.
What they dont tell you on the BP website Joe is most of the 149's running DD-50 will have jacket pre heating. Doing a cold start on a detroit at temperatures < 10
