- Thank you received: 18
International AR-110 Ute
8 years 1 week ago #169373
by grahamjb
Replied by grahamjb on topic International AR-110 Ute
Thanks fellas, the next job will be to make a tow bar because I have had to hand back my Guvvy vehicle because the WA Govt is in a heap of debt
I am thinking of making a hidden tow bar with the Reece Hitch and trailer plug behind the number plate. This will give me a level ride height for my trailer and look neat and tidy as well.
GB
GB
8 years 2 days ago - 8 years 2 days ago #169495
by grahamjb
Picked up a towbar from a Toyota Surf that had been thrown out as part of a front verge collection hoping I could use it on the AR-110.
After running the tape measure over it, I cut off the side brackets to fit it inside the AR-110 chassis
Test fit and all is ok. I also flush mounted the 7 pin trailer connector behind the rear panel so that I could still fit the number plate over it
Not the best photo but this is what it looks like from underneath
The removable Reece hitch was not bent at 90 degrees and had to be fixed
Some heat from the Oxy and the Press soon got things looking better
Weld on a plate for the chain shackles
Finished result
All I have to do now is mount the number plate on a spring so that I can swing it up when I want to use the towbar
Finished result
Last edit: 8 years 2 days ago by grahamjb.
8 years 2 days ago #169502
Replied by hayseed on topic International AR-110 Ute
Graham, get a Number Plate Bracket off an -XF Falcon. Their on a Spring loaded hinge As the Fuel Cap was behind It..
8 years 2 days ago #169503
Replied by Morris on topic International AR-110 Ute
GrahamJB, you certainly have a magic touch with metal. Your designs and workmanship are amazing. Keep the pictures coming, even though they make me feel jealous!
7 years 11 months ago #169743
by wombat 46
Replied by wombat 46 on topic International AR-110 Ute
that is truly amazing work,
not sure i would loan it to the son inlaw to do a tip run though,
Jim
Jim
7 years 11 months ago #169779
by Zuffen
Replied by Zuffen on topic International AR-110 Ute
Graham,
I think you will find the chains are supposed to be attached directly to the towbar not the removable hitch.
This is to stop the trailer escaping if the hitch pin should go AWOL.
7 years 11 months ago #169785
by grahamjb
Thanks for the comments gents and you are correct Zuffen re the chain attachment.
In WA you are allowed to attach the chains to the removal lug provided you use a chain to stop the removable lug from coming adrift.
Extract from the WA rules says:
"Towbars with a removable towing lug should be fitted with safety chain connections on the non-removable part of the towbar. If the chain connections are on the removable lug then the lug must be restrained by an additional chain to prevent disconnection from the towbar if the lug attachment fails."
Don't know how I am going to fit the extra chain though
GB
GB
7 years 11 months ago #169788
by wouldyou
Replied by wouldyou on topic International AR-110 Ute
Graham,
A chain welded to the removable hitch and secured ahead of the holding pin would meet the requirements but be fiddly.
While not meeting the letter of the law a second securing pin would do the job of a chain.
Admire your work.
David.
Admire your work.
David.
7 years 11 months ago - 7 years 11 months ago #169789
by grahamjb
I suppose I could weld a chain to the end of the removable hitch and secure it to the towbar after it has been put into position then it will comply with the WA regs.
Thanks for the idea David.
Last edit: 7 years 11 months ago by grahamjb.
7 years 11 months ago #169805
by Zuffen
Live and learn.
If the chain you used to join the two was inserted in some plastic hose or conduit it wouldn't jiggle around and damage your paintwork.
Time to create page: 0.562 seconds
